timing belt question
  • e30construction
    • Jan 2013
    • 591
    planning to do a complete timing belt tune up and was wondering what all parts do i need? as in everything..all i know is timing belt and water pump..is there any other things? thanks in advance
    93 325i 120k
    mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
    future mods: chip, m3 cams, headers, turbo
  • reelizmpro
    • 9558
    Tensioner...and coolant.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Robotin
      • Jun 2011
      • 4471
      haha perfect
      dont forget to replace the hydrocoptic marzelvaynes
      or your turbo incabulator
      1989 325i SETA stroker [delphin] R3V'd 8/31/2011
      1989 325ix [zinnoberrot] $OLD
      1970 2002 [Nevada]
      Originally posted by Herr Faust Schinken
      guy must have slid into something that doesn't look like a car vs car hit
      Originally posted by ak-
      Must of slid into Rob
      • jeffnhiscars
        • Jun 2011
        • 6011
        The tensioner spring is a must (and its ponly $1) and it makes sense to replace the belts and hoses since they are out anyway. For good measure Id do the cam seal and o-ring as a minimum
        Alice the Time Capsule
        • rodpaine
          • 33
          And don't forget the Blind Plugs.
          -Rod
          Rod's 528e support web site
          A car can be restored many times. It is original only once.
          • E30-325iS
            • Sep 2011
            • 191
            Chances are that numbers 14 and 15 in this diagram will be brittle and crack when you are trying to remove them. Easier to have new ones ready incase they do crack rather than try to put them on after you've put on the radiator, fan shroud, fan etc back on.
            http://www.realoem.com/bmw/showparts...05&hg=11&fg=10
            • e30construction
              • Jan 2013
              • 591
              where would i get 14 and 15? autozone?
              93 325i 120k
                Your dealer or an on-line BMW parts supplier.
                  • 37833
                  As a general rule don't buy ANY parts for your car from AutoZone.
                  I use BMA Parts for most things and TheBMWpartStore for OEM BMW parts.
                  Grover Beach, California
                  BimmerHeads.com
