Broken Timing Belt - What Next?
  • jeffnhiscars
    • Jun 2011
    • 6011
    I called my local dealer and asked who they send their heads to and they said they've been using him for 20 years. Good enough for me. I wouldnt trust any old shop.
    Alice the Time Capsule
    • EatsHondas
      • Sep 2012
      • 404
      Alright the head is off. Haven't looked at the valves yet, but every piston looks like it kissed its fellow exhaust valve to some extent. An intake rocker decided to divide and conquer as well. Here are some bottom-end shots. Still useable though right?
      I'm probably going to start tearing down the head this week and consult with a few local machine shops about rebuild costs.
      I've never torn down an automobile engine of any kind, so every step of this whole process is new to me. Any advice or stories of your previous experiences would be great. Thanks guys.
      1989 325i Lachssilber Sedan
      5-Speed Swapped
      M30B35 Swapped
      MegaSquirt MS3X
      1987 325i Lachssilber Sedan
      260k OEM Automatic Daily Baby
      • EatsHondas
        • Sep 2012
        • 404
        6 bent exhaust valves, 1 broken intake rocker, and 1 bent intake valve. Fantastic. Don't have enough green for all the necessary machine work, so this head is going to sit the bench. It's gonna have to be a junkyard head for the next few years at least.
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        • chance
          • Feb 2012
          • 671
          that sucks.
          I cant remember if I saw an m20 with the head at pull a part last weekend..?
          1991 335is in progress
          • EatsHondas
            • Sep 2012
            • 404
            Originally posted by chance
            that sucks.
            Very much.
            You mean there might've been one or you know for sure there aren't any? Pretty sure the 525i's run an m20 also, that'll increase my odds of finding one. Nate was talking about a yard behind his house that has a few e30's. I'm gonna try to czech that out this week.
            5-Speed Swapped
            M30B35 Swapped
            MegaSquirt MS3X
            • chance
              • Feb 2012
              • 671
              Originally posted by EatsHondas
              Very much.
              I havent been to Myers in a while, let me know when you go there, I wouldnt mine going.
              Just make sure you dont get an 'e" head, as in one from a 325e. they are different than yours
              • EatsHondas
                • Sep 2012
                • 404
                I'd really like to go this week sometime. I'll let you know when.
                Yeah an "i" head has '885' on the casting. I'll watch out for that though. "Why won't it rev past 4 grand?"
                5-Speed Swapped
                M30B35 Swapped
                MegaSquirt MS3X
                • EatsHondas
                  • Sep 2012
                  • 404
                  Picked up a head today from a vert 325i. The cluster looked beautiful and was clocked at 107k miles. That's fewer miles than most clusters stop at, and the head looks beautiful. Golden brown, but no soot or buildup. My old one is disgusting.
                  5-Speed Swapped
                  M30B35 Swapped
                  MegaSquirt MS3X
                  • chance
                    • Feb 2012
                    • 671
                    wooooooooooooooooooo
                    its always fun smashing apart cars at Myers
                    • EatsHondas
                      • Sep 2012
                      • 404
                      For all this trouble, I'm probably going to do a timing belt every oil change so I never have to go through swapping the head again.
                      I've tried three different styles of valve spring compressors from various auto parts stores and they all wrangle dick. Since the valves are recessed so far below the top of the head, I have to use a deep socket on the top of the valve spring while making sure the other end of the tool doesn't slip off the valve and gouge the combustion chamber. I spent ~2 hours on it last night and only got two valves out.
                      "Fun, fun, fun..."
                      5-Speed Swapped
                      M30B35 Swapped
                      MegaSquirt MS3X
                      • chance
                        • Feb 2012
                        • 671
                        "Fun, fun, fun..."
                        surely theres a better way.
                        I had a big valve compressor, but gave it to chris a. You might be able to borrow it from him and see if it works
                        • Cronopoulos
                          • Jul 2011
                          • 2187
                          "Fun, fun, fun..."
                          You don't need to remove the head to swap belts. A machine shop would have it done faster and im sure the bill wouldn't be that terrible either.
                          Project log -- DIRTY 30
                          2.7i * Megasquirt tuned * E85 powered
                          • EatsHondas
                            • Sep 2012
                            • 404
                            My belt broke, ruining the head. Found another to put on instead of rebuilding it.
                            5-Speed Swapped
                            M30B35 Swapped
                            MegaSquirt MS3X
                              You need a C-arm type valve compressor. Sears has one that works fine.
                              • EatsHondas
                                • Sep 2012
                                • 404
                                I'm currently renting one from Advance Auto Parts and it looks exactly the same as the one at Sears. Is there a trick to getting the angle right? I spent a good bit of time trying to figure it out and it's still not easy.
                                5-Speed Swapped
                                M30B35 Swapped
                                MegaSquirt MS3X
