Will a 318 fuel pump and filter fit on my 84 325e? I've looked everywhere and can't find anything on it.
Fitment question (e30)
check realoem?FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
Saab/GM tech2 programming
My for sale thread
1990 325iX for sale or part out
Did you buy something from me? Please leave feedback!
Originally posted by K20RI_211And I have to ask if you make a hobby out of thread-bombing with retarded questions?
I believe the 318/early 325 pumps are the same. Check the part numbers between the 2 chassis.
Plug in the last 7 of your VIN here - http://www.realoem.com/bmw/select.doComment
I don't have the car with me so I'm not sure of the VIN. Anyone with an 84 want to donate theirs?I believe the 318/early 325 pumps are the same. Check the part numbers between the 2 chassis.
positive man. go for it.
The filters are the same as well as the supply system. There would be an issue if your 318/325 was a later model but it isnt. As long as no one has retrofitted or updated anything in the fuel system, then everything from the 318 will work in the 325 and vice versa.Comment
I should have probably noted this in the first post. the 318 is a late model (91). I'm guessing that means that it won't fit at all, haha.positive man. go for it.
Sorry about that man. The problem with the early model fuel pump unit is that the fuel pump and level sender are on the same unit and the early system has a lift pump and a high pressure pump. In a late model, they have only one pump and the level sender is separate from the pump assembly.
The 318 pump can work but it takes a lot of retrofitting to make it operate correctly. You would need to delete the external pump and lines then trim the pump bracket that holds the pump inside the tank. Lots of work and in the end, you are still replacing the pump with a used piece.Comment
Bummer. So what all pumps would work? You seem pretty knowledgeable so what about starters also?Sorry about that man. The problem with the early model fuel pump unit is that the fuel pump and level sender are on the same unit and the early system has a lift pump and a high pressure pump. In a late model, they have only one pump and the level sender is separate from the pump assembly.
as for the starters you will just need one from an early model m20 car. The m10 starters wont work and I believe the late model m20 starters have a one extra wire if I remember correctly.Comment
