digger, this is for you. ;)
The question arose about how much material can safely be removed from ceiling of the crankcase at the bottom of the bores where the rod bolt shoulders get close/contact when stroking a M20.
Unused B25 block + Sawzall = answers.
![](http://i1178.photobucket.com/albums/x363/LJ851/97d25dd3-83fb-498e-93fb-a11626d4363b_zpsf9328824.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/55e7e457-c407-4930-a5c7-b6cce5763b2f_zpsc7605e25.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/80b6c12d-4a67-4e3a-abf6-c66773c3e07d_zpsa8d90bd2.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/5661b553-cfe8-4098-ac07-7b137cac8b59_zps3fe1e6c0.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/a30825ec-12d1-45aa-a9c3-5f0a78ac67d5_zpse1145b58.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/76a87402-b432-444d-898c-f0b737c387b2_zps912cffc3.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/6ce3b1a9-31f6-46d8-af36-1e5074e7ef60_zpseacc394d.jpg)
The casting is fairly rough in the crankcase so act accordingly. Pictured is the smallest measurement i could get on each side. I would guess there is at least a solid 5mm of meat on each side.
Other potential points of interest.
![](http://i1178.photobucket.com/albums/x363/LJ851/047b5f6d-f136-4dbb-b6f6-d93cc5ee0077_zps1e1e55f8.jpg)
![](http://i1178.photobucket.com/albums/x363/LJ851/b2400b8d-9997-4770-a1d7-0f3bd1021b1e_zps37964278.jpg)
Thank you for watching.
The Sawzall is still warmed up if there are an other questions before this block gets recycled.
