Manual Radiator in a Manual-Swapped Car?
  • EatsHondas
    • Sep 2012
    • 404
    So why won't a manual-trans radiator work in an auto shell that's been manual swapped? I've read a bunch of threads about it, but they all say it simply can't be done. Is it physically too big/small? Upper/lower hose ports in a different location?
    I obviously don't need that transmission fluid cooler portion anymore, and I hate that the radiator is a dead giveaway that the car's been swapped.
    Wouldn't the manual radiator have a little more surface area (more efficient cooling) too?
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
  • SpecM
    • Oct 2005
    • 4531
    it will work just fine. who said it wouldn't? 100% the same besides not having a trans cooler. there would be negligible cooling benefits, but it does make shopping easier!
    1989 cirrisblau-metallic 325i
    • dnguyen1963
      • Nov 2011
      • 2651
      Can you post the threads that said it would not work? There is absolutely no reason for it not to work.
      • SpecM
        • Oct 2005
        • 4531
        it works. really. I swapped 5-spd swapped my e30, then later replaced the rad with a man-trans Mcoupe rad
        • EatsHondas
          • Sep 2012
          • 404
          I probably stumbled on some e30 know-it-all's who have never even had one.
          Here's one: http://www.e30tech.com/forum/showthread.php?t=53438
          5-Speed Swapped
          M30B35 Swapped
          MegaSquirt MS3X
          • TobyB
            • 5268
            you can put a automatic's radiator in a manual car but not the other way around.
            this part is true....
            t
            • EatsHondas
              • Sep 2012
              • 404
              t
              Oh I see what he meant, I thought he meant an auto shell that had been swapped. Aren't there plenty of automatic cars with no trans oil cooler?
              5-Speed Swapped
              M30B35 Swapped
              MegaSquirt MS3X
              • SpecM
                • Oct 2005
                • 4531
                no not really
                • kronus
                  • Apr 2008
                  • 13032
                  every auto e30 has a trans oil cooler
                  manual cars can run either radiator with no issue
                  auto cars need one with oil cooler fittings
                  cars beep boop
                  • EatsHondas
                    • Sep 2012
                    • 404
                    no not really
                    I meant cars in general, not necessarily e30's. Thanks for the info though.
                    5-Speed Swapped
                    M30B35 Swapped
                    MegaSquirt MS3X
