dipstick o ring replacement?
  • peytonracer4
    • May 2011
    • 524
    does anyone know of one? there's 2 upper o rings and no lower o ring as far as i know. regardless, i want to replace the two upper o rings to give it a better seal and reduce any possible oil burning. does anyone know of replacements for these? the e46 dip stick looks like the same design and might take the same o rings. i say this because the e46 diagrams provide an o ring part number where the e30 diagrams do not.
    the e46 o ring is 9x2.2
    Just go some place that has an o-ring assortment and pick equivalent parts.
    • 101
      • Jul 2011
      • 764
      Bumping this thread to see if anyone has found a source for the proper oil dipstick o-rings.
      I'd rather take someone's experience here who has found the proper size / material O-rings than deal with Amos and Andy behind the counter of my local Advance O'Reilly Pep Boys Zone store.
      101
      The E30 collection:
      1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
      1987 325is - Delphin / Black Sport (son #3's)
      1987 325i Convertible - Triple Black
      1989 325iX Coupe - Diamondschwarz / Black Comfort
      1990 325iX Coupe - Sterling Silver / Grey Sport
      1981 Fiat 124 Spider 2000 - Green / Tan
      1998 Volvo V70 GLT - White / Tan
      1998 Volvo S70 T5 manual - White / Taupe
      2001 Ford Windstar - Silver / Grey (parts hauler)
      2006 Lexus GX470 - White / Tan (tow rig)
      • dnguyen1963
        • Nov 2011
        • 2651
        Go to local ACE hardware store to find one.
        • TobyB
          • 5287
          I found one in the Harbor Freight '1001 o- ring assortment' box that the previous occupant
          of our shop left behind.
          This is not the most critical sealing connection on the car...
          t
          • modernist
            • Apr 2014
            • 283
            I replaced mine with 3/8x1/16 o-rings -- the fit is close enough to make a good seal. A little snug but works fine.
            1986 327i
            transaction feedback
            DIY thing
            meh
            • rommeldawg
              • Aug 2015
              • 14
              11151714390 they are still offered and list for 1.58 each
              • 101
                • Jul 2011
                • 764
                thanks, I'll try those and report back.
                t
                True. But it is the absolute last place I have any intake air seepage at all. My dipstick is so loose its kind of like
                http://byebyepie.typepad.com/.a/6a00...d9afc7d970d-pi
                101
                The E30 collection:
                • TobyB
                  • 5287
                  ...I can see why this could be a problem, then...
                  heh
                  t
                  • TrentW
                    • 2815
                    That part # is incorrect. Those are the CCV tube o-rings.
                    Hardware store is your friend on these.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      I use the green HBNR ring kit from HF. The alternative is a new dipstick as the rings are not sold separately
                      Alice the Time Capsule
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        If you are really in a pinch and cannot find an o-ring then use some Teflon tape to wrap the dipstick.
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          Before you put Teflon tape anywhere near the internals of your engine think about the times you've ever removed any and where the little bits can wind up
                          • dnguyen1963
                            • Nov 2011
                            • 2651
                            Yes, but one would put it where the o-ring is on the dipstick...perfectly safe. It's a temporary solution to fix a vacuum leak until OP can find the correct O-ring.
