Valve Question
  • gath
    • 577
    Valve Question
    How far below deck does the valve reach in a 885 head with stock HG and stock cam, I mean how many mm the tip of the valve is below deck?
  • chineze
    • 3
    Valve lift with the stock cam is 10.1 mm if I remember correctly, note that this is measured from the valve seat area and not from the bottom of the valve.
    Turbocharged 2.7l M20
    Forged pistons, forged rods, bored block, stock head, KDFI standalone ECU, MSD Ignition setup, T04E turbo running 349 whp
    -Watash Racing Team member-
    • digger
      • Nov 2005
      • 6194
      the answer to this question wont tell you how much piston to valve clearance you'll have.
      • TobyB
        • 5287
        ...but modelling clay will...
        t
        • digger
          • Nov 2005
          • 6194
          t
          exactly
