Same injectors light or dark
M50 injector + MarkD chip won't start
The only thing i removed are the ecu, valve cover, inject harness + c191 plug, fuel rail and injectors. Car runs perfectly and sit for 7 hrs before the swap.
My thought also could be my ecu is dead. But I have to swap back to stock injectors and see how it goes.Comment
main relay ?Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
The two connectors on the injector rail, did you get them switched up by any chance? My car wouldn't start, would crank for days but no injectors. I had gotten those two connectors that go from the rail to the T-stat mixed up. Flipped them back and started right up.Comment
what connectors are you talking about sir? those blue and brown are coolant temp sensors. blue for ecu and brown for gauge. is that what you mean?Comment
You know that doesnt mean it works and the symptoms sound a lot like when I had a bad main. If you can swap in a know good one it would eliminate one possible cause.
^^ we've34 seen that happen more than once :)Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Update:
I read somewhere that they could be stuck closed.
Today i pulled out the m50 injectors and clean them with carb cleaner. After an hour i put it back with no luck. I did the tapping and 9v battery tricks too but no start.
I swapped back to stock injectors and engine fire in an instant. So I conclude the m50 injectors is really stuck closed and I'm needing a new set of m50 injectors so that my markd chip won't go waste.
Thanks a lot guys for your inputs. I really appreciate them.
Regards,
HaroldComment
Really sucks and no warranty but anyway bad things happened. It's kinda my fault though, the injectors stayed in stock room for 3 months and we have a high humidity here in the Philippines. The body of the injectors has some rust so I guess the internal has too.
Will keep updated this post once I get a new set. Though maksinjection.com has no stock at the moment so I have to wait.Comment
