Just did timing belt, low idle now
  • downforce22
    • Aug 2009
    • 3193
    Like the title says, I just replaced my timing belt this weekend and did a general tune up (cap, rotor, wires, air filter, vc gasket). I also disconnected the battery and connected the +/- to reset the ecu.
    Recently did water pump and oil change. The car runs great now. The problem is when I come to a stop and put in the clutch my idle drops to about 500 rpm for 5-10 seconds until the engine catches up and it jumps up to 700 or so.
    The engine does have a cam but it has never done this. Do I have a vacuum leak? What would cause this to happen? Does the ecu just need to adjust after some more miles?
    Thanks guys
  • EatsHondas
    • Sep 2012
    • 404
    Thanks guys
    Yes, intake leaks are very possible. Even if you do everything 100% right the first time around, the odds of breaking a seal/jarring something loose on a 20+ year old car are very high. Double check all your work, then do a smoke test (DIY or professional) to rule out leaks.
    The ECU should be able to retrim the injectors in a very short amount of time/distance (couple of miles).
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
