What oil do you use?
  • claysones
    • Apr 2013
    • 58
    I have a 1990 325is with about 90k miles on her. She seems to not like synthetic oil and leaves drips of it periodically when I let it sit. When I use a non-synthetic it never leaks at all. thoughts on this? what oil do you guys run?
  • SpecM
    • Oct 2005
    • 4531
    I use Mobil One 15w50, but some good non-syn to use are Shell Rotella 15w40 and Castrol GTX 20w50
    1989 cirrisblau-metallic 325i
    • Cabriolet
      • 9620
      you should be running 20-50 year round. non-synthetic. and replace it every 3k.
      Much wow
      I hate 4 doors
      • berlow94
        • Jan 2013
        • 1063
        Liqui-moly 5w40 baby!
        The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
        • campbellj25
          • 181
          I work at a bmw dealer and just put the same synthetic 5w30 I put in all the other cars. I agree it leaks worse than non synthetic.
          • JinormusJ
            • 6887
            Mobil Delvac 15w40 Diesel Oil
            Better than regular, thicker than synthetic
            Has ZDDP additives that our worn out cams need, rated close to what m20s seem to like running (15w50+)
            Don't worry about it being diesel oil; I know modded Supra guys that run it and swear by the stuff
            • digger
              • Nov 2005
              • 6216
              20W is too thick when cold even in hot climates
              • golde30
                • 11464
                i ran castrol GTX 20w50 in my m20, and i beat the living shit out of it daily with no issues. was still running hard @ 200K when i pulled it.
                IG: @Baye30
                • bastianshaw
                  • Jan 2007
                  • 2210
                  Originally posted by cabriolet
                  you should be running 20-50 year round. Non-synthetic. And replace it every 3k.
                  this
                  vr1 20-50.
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Penzoil or GTX 20-50, Mahle filter and a bottle of ZDDP every 3k. Total cost is $25
                    Nothing else makes sense to me
                    Alice the Time Capsule
                    • LowR3V'in
                      • 4209
                      Vr1.
                      it's so good, it's not street legal ;)
                      btw, on both my m30s they both had the back cam lob warn down and
                      I bought a used 284 with the same wear on the same spot.
                      Probably filled with gtx or whatever non-rocker friendly oil it's whole life.
                      • digger
                        • Nov 2005
                        • 6216
                        oil threads lots of opinions..... unless you have controlled tests and proper lab analysis how does anyone on here know that wear is acceptable without tearing down the engine and measuring it and doing it for several oils and on more than 1 engine to establish a trend. Some guy uses xxx-yyy oil and engine seems to run fine for a while doesn't mean its a good oil or that a different oil wouldn't perform better.....
                        personally i would use at most 15W-xx for hot climates and at most 10W-xx for cold climates. a 40 or 50 will both work when upto temp and there are probably more important characteristics than the viscosity. but should change it and filter more often than what the book says
                        • audiquattrot
                          • May 2008
                          • 3836
                          Castrol GTX 20W50.
                          www.instagram.com/snwmble
                          #snwmble
                          Current:
                          '05 BMW M3 - Silver Grey/Imola Red
                          '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                          '15 Mini Countryman - Blazing Red/Carbon Black
                          Past:
                          '01 Audi Allroad - Light Silver/Platinum Saber Black
                          '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                          '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                          '90 BMW 325i - Schwarz/Tan sport *Sold*
                          '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                          • Beau B
                            • Mar 2004
                            • 734
                            Castrol GTX 20W50
                            1988 BMW 325iS
                            • MF DOOM
                              • Apr 2012
                              • 944
                              m1 15w50
                              EDIT: m42 car. somehow i missed that this was in the m20 section
