What oil do you use?
  • evilnickwong
    • Aug 2007
    • 302
    Is there a specific reason not to use modern synthetics (aside from low ZDDP content)?
    I've been using Mobil 1 5w-50 on my M40 engine for some time now without any issues. I also tried GTX 20w-50 way back, but I felt it made the engine feel sluggish. My car runs in a very hot climate btw (Malaysia).
    • MF DOOM
      • Apr 2012
      • 944
      mobil 1 has high levels of zinc.
      • LowR3V'in
        • 4209
        Originally posted by digger
        personally i would use at most 15W-xx for hot climates and at most 10W-xx for cold climates.
        why is that digger?
        • griffincox
          • Nov 2011
          • 98
          I dont mind a few drips of synthetic when I can run it 8-10k miles. I run Mobil1 10W-40 High Milage with a good filter. Add 1 quart when it needs it (3-5k miles) and then change it when it needs another. I buy oil at wally world. Right now its $22.47 for 5 quarts. Filter is $5ish. So you get a great oil change for $30. At my temps in Colorado this is just about the perfect year round oil.
          • digger
            • Nov 2005
            • 6194
            Originally posted by LowR3V'in
            why is that digger?
            oils are a compromise as to what temp and operating conditions they provide their best protection. Since most wear is upon start up and warmup an oil that flows a bit better when at low temp is surely helpful at keeping all the bits apart.
            there is no correlation between low ZDDP and synthetic.......
            everyone should read through all the chapters here
            http://www.bobistheoilguy.com/motor-oil-101/
            apparently for a given viscosity say 10W-40 the syntheitc will flow better when cold than the mineral 10W-40
            • dnguyen1963
              • Nov 2011
              • 2651
              Farm and Fleet 15W40 Diesel oil...$8 a gal.
              • lambo
                Captain Scene Points
                • 10953
                Just switched to Castrol GTX 20W-50 from Mobile One 10W-40 High Mileage Synthetic.
                • bastianshaw
                  • Jan 2007
                  • 2210
                  The problem w this is that the filter is not good for 8000 miles
                  • 603Racing
                    • Dec 2010
                    • 612
                    Brad Penn 20w-50 in my DD and my race car. Though I was given an few jugs of Rotella T so I did use that for a few oil changes in my DD.
                    Moly 5w-40 in the wife's car, but it's an audi. :|
                    90 325i DD/Track
                    03 Durango 5.9
                    Originally posted by e30mpg
                    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                    • chadthestampede
                      • Jul 2008
                      • 3601
                      This thread is a good read:
                      Originally posted by LJ851
                      Feedback
                      • nrubenstein
                        • 3148
                        M1 15w50.
                        I might standardize on the M1 V-Twin 20w50, since that's what the 993TT is happiest with (according to oil testing and quantities of oil blowing out the turbochargers). Probably not, though. V-Twin (which has lots of the right additives, and was designed to not fall apart in air cooled engines) is quite expensive. 15w50 is available in jugs at Walmart.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • Earendil
                          • 1662
                          Because my E30 sees a fair bit of track time, I run 20w-50 GTX, and change it before each event. I go easy on her when she's cold, and flog every last mile out of her on track :)
                          Don't worry about it being diesel oil; I know modded Supra guys that run it and swear by the stuff
                          Oh we'll then! If the Supra Guys do it! Nothing epitomizes the epitome of car maintenance like a supra
                          Sounds about right :)
                          1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                          2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                          I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                          • Cabriolet
                            • 9620
                            read the owner's manual it tells you what oil to run based on the temp. and unless it's winter and below freezing. 20-50 is the best. and 5-30 is never to be used. there are many dyno runs to show that 20-50 non-synthetic is the best for your M20
                            Much wow
                            I hate 4 doors
                            • JinormusJ
                              • 6887
                              It does when these supra's run 700-1100HP DD/track and use the stuff with great benefits with wear, adequate oil pressure, and superb lubrication.
                              So yes.. to DD any 700HP car reliably would be the epitome of reliability.
                              • Cabriolet
                                • 9620
                                the point that you missed is that supra engines run at different temperatures, have different tolerances, different lifters, chain driven(not belt) and are turbo'ed. All of these are factors in to which you must account for when getting the correct oil for the job. that's like saying because my oil works in my Civic it will work in my Porsche... - completely wrong conclusion.
                                Much wow
                                I hate 4 doors
