275 hp goal m20
  • digger
    • Nov 2005
    • 6181
    #31
    Originally posted by Bullet Ride
    The dyno is in shootout mode for that plot which I believe is some standardized method of estimating crank hp so that in theory you can go to any shootout certified shop and get the same readings on their dyno.
    no its rwhp, shootout is nothing to with estimating crank hp. shootout locks out the operator from adding scale factors and fixes correction factors for drivetrain inertia, ramp rate etc so the only correction comes from temp, atmos pressurel, RH
    DD does have a mode where it adds 20% to give crank hp but its basically just a fixed BS fudge factor, this is identified with "S_Hp" on the top of the axis or whatever units are used instead of plain old "Hp" which means its at the wheels. sometimes it even actually says flywheel power when it is fydging the numbers by the 20% factor. this fudge factor mode is used almost always for our European friends
    • LJ851
      • 7919
      #32
      Originally posted by e21jps
      I've hunted down info about your engine around the internet over the years and admired what you have accomplished with the M20, could you do an overview of the history/journey of your M20 and some words and pictures about this new 3.0 build ? I know i would love it and i think the rest of r3v would as well. Glad to have you here on r3v.
      Also post some videos!
      Lorin
      The M30 is God's engine.
      • AbsorbantNut
        Non faccio funzionare questa merda
        • Jun 2010
        • 2491
        #33
        turboturboturbo.
        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
        • E-Thirty
          • 1331
          #34
          Seconded! Would really appreciate it.
          Do you feel like something is trying to penetrate your butthole?
