Are the bmw 325is engines supposed to have a light ticking sound?
  • bmw_fan
    • Aug 2013
    • 12
    Hi, im interested in buying an 325is e30 And Ive seen a couple But they all sounded like they have a lifter tick But idk What the engine is supposed to sound like when its running right. please let me know.
  • TheTacoMan
    • Nov 2011
    • 2308
    If its an m20, pretty normal. A video and Im sure someone on here could dissect if it is the normal m20 tick or not.
    • Killacortes
      • 1937
      Light ticking is pretty normal. I run 20w50 oil to quiet it down
      r3v does not fuck around. First you get banned, then they shoot you
      • bmw_fan
        • Aug 2013
        • 12
        Is it supposed to have a tick? Or is it just normal for a worn motor? Because I've seen the 318 with the m42 motor with a tick and a couple m20's with it, But I have a 533i e28 with the 3.2 And it doesn't tick. And I want the m20 I just dont wanna get ripped off..
        • digger
          • Nov 2005
          • 6198
          everything brand new and adjusted hot it is quiet but a bit of a tick is not a problem at all
          • bmw_fan
            • Aug 2013
            • 12
            Don't you just have to Take the valve cover off And adjust the valves? (If there isn't any damage) And that will stop the tick? Or could it be another problem?
            • Nisse Järnet
              • Aug 2013
              • 1221
              It can be other problems like worn cam but often its just valve adjustment.
              E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
              E30 M50 6 spd 764whp @ 24psi.
              E30 M20 6 spd 675whp.
              • EatsHondas
                • Sep 2012
                • 404
                High mileage motors will still tick even after a proper valve adjustment. It's the valve guides loosening up around the valve that cause the ticking. You'll either have to live with it or rebuild the head. Run 20w50 oil, adjust 'em, and forget 'em for another 15k.
                1989 325i Lachssilber Sedan
                5-Speed Swapped
                M30B35 Swapped
                MegaSquirt MS3X
                1987 325i Lachssilber Sedan
                260k OEM Automatic Daily Baby
                • bmw_fan
                  • Aug 2013
                  • 12
                  Ok How much would it cost to rebuild the head? Because the guy i might buy this car from said that it has a remanufactured head. And he says all e30s run with a slight tick, And its hard for me to to think thats true.
                  • Killacortes
                    • 1937
                    Like 80% of e30s will have a slight tick. Its true
                      • 34844
                      stock E30 injectors are also pretty loud
                      properly adjusted valves should tick a little at idle, but it shouldn't be loud or anything.
                      if it's a slight noise, it's probably normal.
                      • bmw_fan
                        • Aug 2013
                        • 12
                        Thank you guys for the info. really helps alot. But now if I could just find a nice one i will be happy ha.
                        • NeedaE30
                          • 397
                          Well the m20 sounds like a loud sewing machine... i've owned 3 m20's and every single one of them had loud mechanical valve lifters and loud as fuck injectors.. even when injectors are perfectly cleaned and flowing properly and valves adjusted to spec motor running beautifully still very ticky sewing machine sounding engine... just get a cone filter and a loud ass muffler if you dont like the tick, use thick oil.. or just swap in a 24v motor with hydraulic lifters.. sup to you
                          • bddog
                            • 351
                            Nature of the beast. If they are not making a little noise, then they are adjusted too tight.
                            • 1owNslo
                              • Apr 2012
                              • 334
                              lol i believe one of the mods on here... his lil signature is ... "a tappy m20 is a happy m20" referring to valve noise. its normal.. mine has it.. BUT there is a difference between NORMAL and ABY-NORMAL ;)
                              10 minutes... then we invade China.
                              We'll begin with the small town of General Tso's,
                              And move to the Orange chicken province.
