Can't get the injector harness clips off!
  • davesmystery
    • Jun 2013
    • 106
    So I've read a number of methods for removing the injectors and none of them have pics on how exactly to remove these dumb clips. Most people say a screwdriver but there doesn't seem to be a way to get the tip of the screwdriver parallel with the clip groove to push it all the way back. It would have been far more helpful if BMW made them like the temp sensor plug clips. Anyway, here's what I'm looking at for reference.
    Here's the backside of the clip, I'm guessing this has to come out towards me?
    Here's the "front" of the clip, the little metal bar doesn't extend across the clip over the injector so I have no idea how to push it back. There's very little room to get in there with anything.
    Finally, I can see the fuel rail bolts, but there's no way I can get anything to them without removing the harness first.
    Help is much appreciated, I'm trying to get them out to send to MEPEH for cleaning/testing.
    1992 325ic, Alpine over Indigo.
    • 34844
    just pull up on the harness. it pops off. you don't have to remove the clips.
    • Mr. Tasty
      • Jul 2011
      • 3421
      just use a small flat head.
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
        • 34844
        again, you don't need to pull the clips off. just pry up on the harness. they are designed so you don't have to do anything with the clips.
        • FLG
          • Sep 2011
          • 3165
          Just pull
          Also remove the valve cover, will make things easy not to mention it's nearly impossible to get the injectors out with it on.
          Fuel rail bolts are simple and just need a 10mm socket with an extension
          Sent from my SCH-I545 using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • JinormusJ
            • 6887
            Force upwards, you just apply
            I remember I raged because I couldn't get the injector harness off one time to work on the Thermostat housing; it took me 30 minutes of trying until I grew fed-up and just rage-yanked it and it popped right off.
            The mechanisms in the clip is just a metal clip that acts as a spring so it doesn't pop off unintentionally; pulling on it and applying enough force will take it off no problem.
            • mpowerful
              • Jul 2013
              • 1273
              I use a 90 degree dental pick. I get down on the side of each one and cock it around at 45 deg angle. That way you dont risk breaking the clips or plastics. Anyway it will come off if you yank hard enough though.
              • digger
                • Nov 2005
                • 6194
                you do not need a screw driver just pull the bastard up
                • Tom.
                  • Sep 2012
                  • 121
                  this is the method I use too.
                  • Balleristic31
                    • Aug 2009
                    • 4198
                    This. I have broken injectors ripping harnesses off at the junkyard
                    -NICK
                    • davesmystery
                      • Jun 2013
                      • 106
                      Well I bought a dental pick (wanting to err on the side of not-broken injectors) and got the first one somewhat loose, started wiggling it and wound up popping the first three off then was able just to wiggle the rest off. I guess I got lucky it was just the first one that was stuck, it had all sorts of crud on the inside of the connector. Thanks for the help! Now I just gotta get those injectors out.
                      • EatsHondas
                        • Sep 2012
                        • 404
                        Just pull. GENTLY. Start at one end, get that popped off, then work the other end. Once they're both up, pull on both end at the same time to pop the middle ones off. Every time one lets go, move your hands farther towards the middle to avoid snapping the plastic harness.
                        If you try the screwdriver/dental pick method, you'll be in there for hours. And you'll probably launch a few clips into the engine bay where they'll be lost forever.
                        1989 325i Lachssilber Sedan
                        5-Speed Swapped
                        M30B35 Swapped
                        MegaSquirt MS3X
                        1987 325i Lachssilber Sedan
                        260k OEM Automatic Daily Baby
                        • davesmystery
                          • Jun 2013
                          • 106
                          Update - I'm glad I got my injectors out.
                          Yeah, I'd say it's time for a rebuild.
                          • fresh_TD
                            • Aug 2013
                            • 2457
                            man those are filthy..I just pulled mine off and they were the same(dirty as fuck) just make sure you get new seals for those, I just picked some up for like $40 for 12
                            '91 318i (Alpine) - daily
                            '88 325ix (Zinno) - drive here and there!
                            • Cloudbase
                              • 1795
                              I used the bitch clip tool from harbor freight to pull up on the entire wiring assembly. Worked great.
                              JOY IS AN E30...
