what is the maximum HP that an tuned NA M20 can reach
  • Ray Smoodiver
    • Jun 2004
    • 8809
    Originally posted by kistler#7
    2.8L, 14:1 comp, E85 fuel, peak power at 8000rpm. 259 kw at the wheels, thats 347 whp.
    Here's the thread where the builder talks about it, some doubt the dyno results but I didn't read the whole thread to see the outcome.
    Link to thread?
    • BMW B3 2.5
      • Jun 2010
      • 52
      i am just curious what number can an NA m20 reach but from what i read over 250 HP is very hard and expensive
      • Bimmer_man
        • Jan 2013
        • 1478
        your looking at $2,000 for a 3.0 stroker and about another $1,400.00-$2,000.00 in just head work. Then there is the tuning to take full advantage of the air flow you need to ditch the AFM and get either a Miller WAR chip MAF conversion or Megasquirt and thats another 800. Then the headers and exhaust work about another 1000. Trust me the M20 is a easy and cheap motor to maintain at stock levels but to tune this bitch can get vary vary costly for little gain.
        Float like a cadillac sting like a Bimmer!:)
        • digger
          • Nov 2005
          • 6195
          Originally posted by ak-
          You're mistaken. It was 732hp.
          well i am dylesic
          • ak-
            • 12422
            Originally posted by digger
            well i am dylesic
            Apogolies
            1991 325iS turbo
            • digger
              • Nov 2005
              • 6195
              it is not that hard all to reach 250hp crank on a big stroker if you do the right things.
              you can make circa 330bhp on 98RON/93PON but alot of time/money needs to be invested in the head and intake manifold.
              if you want more than 330bhp then you need to use better fuel, alot more compression and more cam duration (non streetable levels) that the higher compression permits
              • kistler#7
                • Jun 2013
                • 186
                Originally posted by Ray Smoodiver
                Link to thread?
                forgot to copy and paste it
                m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
                http://www.r3vlimited.com/board/showthread.php?t=338818
                • 4x4_e30
                  • Sep 2013
                  • 164
                  Here's E21jps's build, 293rwhp on 2940cc using an ETA "200" head
                  • digger
                    • Nov 2005
                    • 6195
                    Originally posted by 4x4_e30
                    here's e21jps's build, 293rwhp on 2940cc using an eta "200" head
                    http://www.e30tech.com/forum/showpos...&postcount=131
                    731
                    • 4x4_e30
                      • Sep 2013
                      • 164
                      731
                      When he said he didn't make things any larger than the 731 casting I assumed he used a 200 head.
                      Did some testing today on a 200 series head and i was even able to take that port out enough to reach my flow target no problems so thats both 731 head and 200 head were fine. So i must have just got unlucky with the AMC due to its large core shift.
                      Im not making the entry of these ports any larger than a standard 731 casting and even inside they are not huge by any means its more about shape than size. I am a big believer in high velocity and optimum lower lift flow.
                      • digger
                        • Nov 2005
                        • 6195
                        i believe he used either BMW 731 casting or AMC 731 not sure which was used on the engine as he did both. when he means any larger than a 731 im pretty sure he means the port entry size which is about 36/37mm. you dont use 44mm valve without making throat and minimum cross sectional areas larger especially on the 731 where it is tiny at the guide less than D30mm iirc
                        in either case it bears no resemblance to the original port, many many hrs of labour not your run of the mill port job you get from a random head guy who can do one kind of valve job and just grinds metal for the sake of it due to no experience in these engines. in these parts getting someone to do that is probably 2 to 3k labour and you gotta hope they know what they are doing
                        • TobyB
                          • 5288
                          Why bother? If you're racing, you build to the rules. For the street, if you don't go
                          M52/S52 etc then you're just masochistic.
                          If it's numbers you care about, that is. If you don't, then you wouldn't ask.
                          The M20 is the only BMW engine never built for racing (*Wes Hill) and was really built for
                          the gas crisis of the late '70's. They never built an S20- and there WAS even an S42.
                          So if you want a nice big number, start with a DOHC engine. You'll START where an M20
                          starts to get high strung, and you'll have spent a lot more to get there.
                          t
                          • SkiFree
                            • Jun 2011
                            • 2766
                            Toby, how is that relevant to the thread? Whether you like the M20 or not, or if its the "right choice" of engine in the first place has nothing to do with what we're talking about. I think you're in the wrong section.
                            ADAMS Autosport
                            • digger
                              • Nov 2005
                              • 6195
                              not many 24V M50/M54/S52 engine make as much power as the 350rwhp 2.8L and 290rwhp 3L engines above..... you need a proper 24V S50B32 or S54B32 to come remotely close make those numbers not M5x based engines
                              why would i waste time swapping in crappy M52/S52 engines when LS engines exist......
                              • TobyB
                                • 5288
                                That's not the first time that's been said.
                                t
