Rocker arm shaft
  • KDAWG97M3
    • Sep 2009
    • 347
    Rocker arm shaft
    So I broke the two front rockers..#1 cyl. I have slid the shafts back to the firewall, now they are stuck and I can't move them..what is the issue I have tried everything.,why are they stuck? Any help? Ay ideas? Thanks
  • Gregs///M
    • Mar 2012
    • 2459
    You need a belt wrench to twist and turn them back toward the front of the car.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • Ether-D
      • Sep 2011
      • 2838
      I used some emery cloth wrapped around the shaft then grabbed that with channel locks. Gently pivot the shaft and pry against the firewall with a pry bar.
      Originally posted by Andy.B
      I was born on 3/25…
      • jeffnhiscars
        • Jun 2011
        • 6011
        Don't grab it where the rockers ride if you do this as it is going to score the shaft.
        Alice the Time Capsule
        • KDAWG97M3
          • Sep 2009
          • 347
          I can't get it. I started to take the head off shit. I have zero time. I almost want to drop in a motor. :) I just can't get the intake side to move plus the exhaust side get bound up it is a mess
          • Ether-D
            • Sep 2011
            • 2838
            Sorry bro. That shit sucks.
            I was born on 3/25…
            • KDAWG97M3
              • Sep 2009
              • 347
              Might have to sell it :)
              • redlightpete
                • Mar 2012
                • 264
                Did you relieve the rocker tension by sliding the rockers off the valve stems? This is typically the first step in removing the rocker shafts.
                • KDAWG97M3
                  • Sep 2009
                  • 347
                  Oh yeah. Two rockers are stuck on the shaft and the shaft won't move. I give up. Setting fire to it tonight. :)
                    • 37829
                    In the time you've been thinking about it you could have just pulled the head and done it the right way.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • KDAWG97M3
                      • Sep 2009
                      • 347
                      Huh? I am in the process, but I have two stripped head bolts, the torx heads are messed up..hence why I went this route. I have everything loosened except these two head bolts...how can I get these out?
                      • Ether-D
                        • Sep 2011
                        • 2838
                        You can grind the heads off those stuck head bolts w/an angle grinder. Remove them after you get the head off.
                        I was born on 3/25…
                          • 37829
                          Whoops I guess I only saw the rocker shaft part. Sorry!
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • KDAWG97M3
                            • Sep 2009
                            • 347
                            Putting in a new motor!! Build this one for later!!!
                            • Andy.B
                              • Sep 2011
                              • 1650
