victor reinz gaskets
  • Ryann
    • 3350
    #31
    Originally posted by SkiFree
    For every person that's done a proper job and still had legitimate issues, there's 10 that use the "crappy gasket" excuse to write off a crappy installation (like not even bothering to resurface the head).
    This. The average r3v wrencher is a mom's-driveway rookie.
    • bddog
      • 351
      #32
      Sorry but how does this relate? If you're looking for a more direct comparison, try the M10 engine where VR hg's are used routinely to great effect (and are a hair bit more expensive then some other options).
      DUH. Cast Iron and Aluminum. What is your car made out of?
      • bddog
        • 351
        #33
        I'm not disputing the quality difference, I'm disputing the negative stigma surrounding the VR gaskets. I've had them work fine for 50k many many times. Given the negative connotation around the VR's I tend to sell the elring upper kits (and oem or goetze standalone head gasket).
        It seems too many people are milling heads that are not warped. You can only take so much off before the head becomes useless. A straight edge and a feeler gauge will tell you if it is within factory tolerances. If you shave it now, when it warps, you may have to throw it away.
        • SkiFree
          • Jun 2011
          • 2766
          #34
          Are you telling me you're not aware of what the M10 is?
          ADAMS Autosport
          • DesertBMW
            • Aug 2011
            • 1043
            #35
            Victor Reinz head gasket lacks sealing quality around main oil passage between cylinders 3 and 4 on the exhaust side. It will start leaking there within a year for sure. Many vendors state that VR is OEM, this just fools lots of people and job never gets done right.
