victor reinz gaskets
  • Jahman093
    • Sep 2012
    • 183
    Im doing a full gasket refresh on my m20b25 im about to swap into my 325e and dont know/ cant figure out where the o-rings and washers go.
    The 3 o-rings and 5 washers
    I know 1 o-ring is for oil level sensor but the other two I don't have a clue.same for washers
    http://www.bmaparts.com/ShopByVehicl...et+Set&mode=PA
    Also on the headgasket set there are two o-rings that are the same size and a very small o-ring i have no idea where they go
    any and all help would be appreciated
    thanks!
  • digger
    • Nov 2005
    • 6178
    orings might be for thermostat and cam cover or either end of the vent tube from block to manifold. might also be for the oil filter housing i need them in my hands to work out. goto the diagrams on real OEM they might help
    i highly recommend getting a Goetze head gasket if you can, it is a much better quality item the ones that come in the kits. i only use Goetze or one from dealer which might be the same manufacturer. i use the one from kits for test fitting checking clearances
    • Dagamus(NM)
      • 620
      For sure. Those head gaskets leak like no other. Sure the oem BMW gasket may be expensive but worth the money to not have to do the job twice due to oil leaking. Goetze is better than the VR but still not the best.
      Gun control means using both hands
      Sex, Drugs, Rock 'n roll. Pick two.
      • Kevinl
        • Oct 2012
        • 897
        Do not use a victor reinz head gasket
        1989 BMW 325is Lachsilber metallic 5 speed
        2007 BMW 335i KARMESINROT 6 Speed manual
        2011 BMW X5 35I
        • E30_Pare
          • 7801
          used a victor reinz oil pan gasket on my 190.. its leaky, but more gasket sealer fixed it. I wouldn't use again though.
          DREWLIENTE
          1$ PShops PM me
          • AndrewBird
            The Mad Scientist
            • 11898
            There is an o-ring on the dip stick tube.
            • e30kawi
              • Feb 2013
              • 75
              There is also a rubber o-ring for the drain tube running from the intake to the oil pan.
              • fresh_TD
                • Aug 2013
                • 2457
                ? ? ? I've used vr head gaskets with zero issues
                Sent from my GS4 Active
                '91 318i (Alpine) - daily
                '88 325ix (Zinno) - drive here and there!
                • cabriodster87
                  • Jan 2011
                  • 1042
                  yes, "bitch tube" two Orings. one upper and one lower
                  Reich und Roll!
                  • Kevinl
                    • Oct 2012
                    • 897
                    They are known to leak oil from the head gasket on M20's
                    2011 BMW X5 35I
                    • SkiFree
                      • Jun 2011
                      • 2766
                      Sorry, but typically when someone complains of a VR hg leaking it's a red flag to me that they shouldn't be working on an engine.
                      Are there better HG's available? Sure. but if done correctly the VR's work fine.
                      ADAMS Autosport
                      • Cabriolet
                        • 9620
                        This is so true. I have never once seen a VR HG last more than 25k miles. they have inferior construction. This is a fact with solid proof. I now only use Goetez or BMW HGs. Never once had or seen an issue with any engine I built using these gaskets.
                        Much wow
                        I hate 4 doors
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Not decking the head after it has been off is probably the most likely culprit to a leaking HG.
                          • digger
                            • Nov 2005
                            • 6178
                            they are shit quality, looks like its made from the same black cardboard i used to play with in kindergarten
                            • mpowerful
                              • Jul 2013
                              • 1273
                              The bitch tube has washers too.
