victor reinz gaskets
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    • KIRIEIW
      • Dec 2012
      • 3385
      This is so true. I have never once seen a VR HG last more than 25k miles. they have interior construction. This is a fact with solid proof. I now only use Goetez or BMW HGs. Never once had or seen an issue with any engine I built using these gaskets.
      I used a victor reinz head gasket in my car with no problems? Also cabriolet my friends car has a victor reinz gasket with some airline sealer, my dad and me used sealer on every gasket on his engine (except head because its not suppose to be applied there) but this kid does a really crappy job with cleaning parts, removing them, ect. Pretty sure he contacted you about his little project he has going on.
      1992 e34 Touring- S50 Swap
      1992 325i-S50 Swap (SOLD)
      1991
      • Cabriolet
        • 9620
        ya he did. i told him that i would not install the engine with the crap VR HG&bolts.
        Much wow
        I hate 4 doors
        • z122643
          • Aug 2011
          • 286
          I have had problems with all VR products I have used, from valve stem seals to head gaskets. I don't really know why. But a prime example for the head gasket issue was I had two M20 engines, both were identical stock rebuilds. Both had decked heads and blocks. I used a VR on one and a BMW one on the other. The VR leaked coolant outward after ~30k the BMW one has 50k and no issue (knock on wood)
          [/SIGPIC]"we are so totally screwed!"
            • 34844
            Originally posted by SkiFree
            Sorry, but typically when someone complains of a VR hg leaking it's a red flag to me that they shouldn't be working on an engine.
            Are there better HG's available? Sure. but if done correctly the VR's work fine.
            I've done the VR M20 gasket properly.
            it still shit the bed after ~50k and leaked oil continuously after the first 10k. it started seeping coolant at about 25k.
            the difference in quality from the original BMW gasket and the VR gasket is indisputable.
            the other parts mostly seem fine to me. I have VR headbolts on the car now (installed with a Goetze HG).
            • Jahman093
              • Sep 2012
              • 183
              thanks for all the help guys! I will definitely be using a different headgasket
              • SkiFree
                • Jun 2011
                • 2766
                I'm not disputing the quality difference, I'm disputing the negative stigma surrounding the VR gaskets. I've had them work fine for 50k many many times. Given the negative connotation around the VR's I tend to sell the elring upper kits (and oem or goetze standalone head gasket).
                For every person that's done a proper job and still had legitimate issues, there's 10 that use the "crappy gasket" excuse to write off a crappy installation (like not even bothering to resurface the head).
                ADAMS Autosport
                • Cabriolet
                  • 9620
                  Andrew, only one of the VR HG that i've installed that didnt fail was on my first eta. ( i aslo sold the car before i did 10k miles on it) i have decked and installed my HG according to spec and the utmost care and seen all three fail on the m20b25. i even installed them at night to ensure the coldest temperature possible.
                  however, i have not seen any VR gasket other than the headgasket fail.
                  Much wow
                  I hate 4 doors
                  • wilholl
                    • May 2012
                    • 518
                    you guys are getting me very worried.
                    I have a VR gasket set to replace the head on my bronzit.
                    Now I don't want to use it, at least the head gasket anyway.
                    1988 325 non-letter Seta "Bronzit"
                    1991 325ic "Laguna Green" (Sold)
                    1993 325i "Laguna Green/Silver" (Sold)
                    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                    2000 528i Titansilber/gray m-sport
                    2000 528i Titansilber/black m-sport(sold)
                    2001 525i Anthracite m-sport(sold)
                    2013 750i Black/Black m-sport "Beast"
                    • SkiFree
                      • Jun 2011
                      • 2766
                      Fair enough, but I have seen legitimate failures for each head gasket including the OEM as well.
                      ADAMS Autosport
                      • digger
                        • Nov 2005
                        • 6182
                        go OEM or goetze, some parts are just not worth skimping on
                        • TobyB
                          • 5286
                          VR is working for me just fine. When it fails, I'll replace it.
                          Because racecar.
                          t
                          • bddog
                            • 351
                            I ran into the head gasket problems years ago with my Datsun Roadster. Cast iron block with an aluminum head. The differentiated metals expand and contract at dissimilar rates.
                            A superior head gasket is needed. Use the best one available, to avoid premature failure.
                            Armed with this knowledge it seems almost criminal to install the inferior product. If it doesn't fail on you, then you are just passing the problem on to the next guy.
                            • Earendil
                              • 1662
                              Because racecar.
                              t
                              You, I like you.
                              Some of us don't want to pay $2000 to have a head gasket replaced prematurely. Others, well we're just looking for a reason to throw our heads on a bench and spiffy up more shit. Because racecar.
                              1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                              2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                              I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                              • SkiFree
                                • Jun 2011
                                • 2766
                                Sorry but how does this relate? If you're looking for a more direct comparison, try the M10 engine where VR hg's are used routinely to great effect (and are a hair bit more expensive then some other options).
                                ADAMS Autosport
