M20 2.7i pinging /or stutter after 4krpm
  • e30m20TurbO7
    • 1203
    I have a pinging or a stutter after 4000 rpm when I gir it the beans. When I keep it below 4k it drives fine till I punch it.
    I don't have my o2 sensor hooked up right now because the wires are frayed on the the connector so I need to splice a new connector in.
    The car is a 318is with a m20 swap with a bav auto chip
    Using original fuel filter. And I'm running a new 318is pump
    The pump is the same but the housing is different so that explains difference in part numbers.
    Need some suggestions
    I have a check engine light on. Running a 318 cluster
  • kistler#7
    • Jun 2013
    • 186
    Do not run the car anymore until you have an o2 sensor, especially with new management. Finish your swap then drive it
    m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
    http://www.r3vlimited.com/board/showthread.php?t=338818
    • Gregs///M
      • Mar 2012
      • 2459
      The 318 fuel pump also provides a lower pressure than required by the M20 motor i think. Might wanna check the bentley manual to see the nominal fuel pressure of the 318 vs the 325i.
      I know for a fact that the motronic 1.1 M20 requires 43psi at idle.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • squidmaster
        • Aug 2011
        • 2666
        The 318i system (late model at least) is 3 bar. Having a fuel pressure gauge hooked up will let you see if that is your problem.
