Dropped a washer down the bitch tube
  • Klug
    • Sep 2011
    • 804
    If the bitch tube wasn't a bitch enough, I dropped a washer from my intake mani down the shoot.
    1) Does this empty directly into the oil pan?
    2) Should I be okay and hope that the magnetic plug collects it?
    3) Should I be worried if anything sucks it up?
    I hope I don't have to take the oil pan off again...I just replaced my gasket less than a year ago.
    Thanks!
    555Garage - Kingston, PA
    '13 BMW e70 X5 35d
    '95 BMW e34 525i
    '92 BMW e30 325i S52 Vert (Quade the Vert)
    '92 Range Rover Classic
    '90 Range Rover Classic
    '89 BMW e30 325i Coupe (The DIRTY30)
    '81 VW MK1 Rabbit Caddy Diesel
    '76 Honda CB550K Cafe/Brat
    '67 Pontiac LeMans
    '24 Model T Depot Hack
    ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
  • mpowerful
    • Jul 2013
    • 1273
    It does lead right into the oil pan. Id take the bitch tube out and fish through the hole with a small telescoping magnet. Maybe the washer didnt go far.
    • Ether-D
      • Sep 2011
      • 2838
      If you don't find it I wouldn't worry about it. It can't go anywhere.
      Originally posted by Andy.B
      I was born on 3/25…
      • Cletonius
        • 2809
        I dunno man, it would drive me insane just knowing it was in there. I'd be hearing all sorts of phantom noises and stuff for sure.
        - Josh
        1990 325is
        Need a shift boot?
        Looking to buy shift boot frames, PM if you have one to sell
        Here's what happens when you let the internet pick your license plate
        • actletpone
          • Oct 2013
          • 20
          Agree, try the magnet idea.
          • AndrewBird
            The Mad Scientist
            • 11898
            It might not go anywhere, but could cause a restriction, causing oil starvation, and then your engine is dead.
              The washer is now laying in the bottom of the oil pan.
              • Cabriolet
                • 9620
                i've found all kinds of stuff in the pans i have changed for people. as long as they are small i havent seen an issue.
                Much wow
                I hate 4 doors
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  You should be able to drag a powerful magnet along the outside of your pan to move the washer and either fish it out the bitch hole or, if its small enough, it might drop through the drain hole
                  Alice the Time Capsule
                  • essi1553
                    • Apr 2012
                    • 440
                    I've also read that there is a filter on the oil pump (probably not a replaceable one) that would prevent anything substantial from being sucked in. If you get a strong enough magnet im sure you can have it pulled from the same hole, not sure if it would slide through the oil drain plug (dependent on size).
                    • Jaxx_
                      • Dec 2009
                      • 1880
                      it's a wire screen to stop big particles(such as washers lol) from being sucked up, but that doesn't mean that it won't stop flow.
                      doesn't the m20 have a place for oil level sensor? how big is that hole? Either way, you'd be on the right track to get that washer out before it causes oil starvation issues, or somehow gets thrown into the rotating assembly.
                      • Ether-D
                        • Sep 2011
                        • 2838
                        If that little washer is enough to stop your oil flow, you had a huge problem already.
                        I was born on 3/25…
                          • 34839
                          it's not going to get sucked in the screen. it's going to sit there in the bottom of the oil pan.
                          I wouldn't worry about it, personally.
                          • Klug
                            • Sep 2011
                            • 804
                            Awesome, thanks for everyones input. Im going to try the magnet idea, if I come up empty I'm just going to cross my fingers and forget about it.
                            And if something does happen, it gives me more reason to get started on swapping out the m20.
                            Thanks.
                            '13 BMW e70 X5 35d
                            '95 BMW e34 525i
                            '67 Pontiac LeMans
                            • Swanny
                              • Mar 2012
                              • 2834
                              Or drop the oil pan? When was the last time the gasket was changed?
                              Swanny!
                              SUCKERS.
