M20 hesitation
  • dougie30
    • Apr 2012
    • 1708
    M20 hesitation
    My car has recently started doing this thing where while im on the highway around 2800-3k it feels as if im pushing the breaks slightly. It happens randomly every 5 mins maybe?
    Im thinking it could be my afm possibly, but im not sure. Any ideas would help
    Sent from my SPH-L710 using Tapatalk
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
    The first thing I'd check would be the fuel system. Tee a gauge into the rail supply line and zip tie the gauge to a wiper. Then see what the pressure does when an event occurs.
    • dougie30
      • Apr 2012
      • 1708
      Good idea I think ill give that a shot this weekend. Where would sell a girl pressure gauge that would work ?
      • TobyB
        • 5287
        Hmm, I haven't seen a girl pressure gauge in years- since I was in college, I think.
        But there are stores out on Aurora that claim to sell that kind of hardware.
        As for a FUEL pressure gauge, you can easily use an oil pressure temporarily, with
        a tee and some high- pressure hose....
        hee
        t
        • dougie30
          • Apr 2012
          • 1708
          Lmao sorry about that.. but yes I meant fuel
          • squidmaster
            • Aug 2011
            • 2666
            Does sound like a fuel issue, fuel pump perhaps. Like said, monitoring pressure would be ideal. Let us know!
            • Cabriolet
              • 9620
              after checking fuel. this also can be caused by a dying crank position sensor, flaky AFM or acting up TPS.
              Much wow
              I hate 4 doors
              • dougie30
                • Apr 2012
                • 1708
                Also found out that my fuel tank leaks if I fill it above half tank. Like leaks pretty bad. Would that cause low fuel pressure? Or is the tank not pressurised?
                • 6SPD
                  • Feb 2013
                  • 243
                  I had a similar issue where I would be driving and the car would just fall on it's face performance wise. It would seem to cut throttle input to maybe 5-10% regardless of throttle position. I went through fuel pump, fuel filter, metered fuel pressure, afm, intake boot, and the ignition wires. Turns out it was a less than ideal wiring job on the 02 sensor causing the car to run rich, since then I've been running with the sensor unplugged until replacing it with my swap.
                  Hopefully this of some help, if not best of luck.
                  À la folie
