325ix head question
  • Axval
    • Feb 2014
    • 4
    325ix head question
    Hello all,
    I have an 87 325e with the eta engine. My friend had a 1988 325IX that gave him transmission problems and was rusted a little too much for repair without major $$$. He has the whole engine and he said if i went and picked it up it was mine.
    My question is is 325ix head the same as "i" head? i want to do the "i" head swap on my eta for later turbo applications. he has the ECU for his too wich i can have but i dont know as being IX it changes in anything compared to the "I" ECU. Just in case i have an "I" ECU.
    I want to do the whole head swap including intake, ecu etc. And if the head works would it be prudent to throw some ARP bolts in there while i do the swap for the latter turbo setup?
    Thanks
  • TehRaydarlover
    • Mar 2013
    • 544
    The ix head and ecu are the same as an I. You should be good to go.
    Build Thread
    Rear Diff Rebuild
    Rebuildable Viscous Coupling
    Transfer Case Rebuild
    "Life is simpler with 12 valves"
      • 37833
      ^ Yup.
      Grover Beach, California
      BimmerHeads.com
      • nomansland92
        • 1657
        Do you need to change the wiring harness with a I swap? In that case the ix wiring harness is a little bit different. Don't quote me on this but I believe just a few wires a longer but I'm not positive on that
        IX being restored here
        Ix turbo build here
        • mpowerful
          • Jul 2013
          • 1273
          ^should work though.
            • 34844
            the only difference in the harness is the wiring for the ABS, which the '87 car won't have, so it doesn't matter.
            also clip pin 20 from the C101 to avoid a fire.
