help me please
  • hakop_e30
    • May 2014
    • 90
    help me please
    i dont know whats wrong with my e30 heres a video of what it does http://www.youtube.com/watch?v=UncIa...XU36gm3A4xyYQg please help me and if this has ever happened to your e30 what was it
    thanks -hakop
    1989 BMW 325I Mtech 2
  • NoM54me
    • Feb 2014
    • 158
    So we have to watch a video to tell you what's wrong, eh? Come on, that's the lazy way out. If it's a rough idle, maybe you have vacuum issues. Try describing the problem with words.
    • dnguyen1963
      • Nov 2011
      • 2651
      I watched the video...no big deal. To me it is easier to watch and listen for the problem than reading half a page of description. There is both vacuum leaks and loss of timing in your car. Check for leaks first then trouble-shoot the timing.
      • hakop_e30
        • May 2014
        • 90
        It's not the timing or a vacum leak it only happens when I'm low on gas like my engine wants to stall on me
        • hakop_e30
          • May 2014
          • 90
          • uturn
            • Dec 2010
            • 1006
            You solved your problem!
            • digger
              • Nov 2005
              • 6194
              tank looked pretty full to me in the video.
              • hakop_e30
                • May 2014
                • 90
                The gauge is messed up
                • hakop_e30
                  • May 2014
                  • 90
                  bump
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    IF this happened only when you are low on gas then tee in a pressure gauge and see if your fuel pump is delivering the correct amount of fuel to the rail. I suspect that your fuel pump is on its way out.
                    • hakop_e30
                      • May 2014
                      • 90
                      i replaced it with a brand new one i changed to pumps or somewhat like that and the fuel relay as well
