No DIY for injector replacement?
  • Zreberlcoe
    • 1555
    I really need to make a video.
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
    • jeffnhiscars
      • Jun 2011
      • 6011
      Originally posted by Zreberlcoe
      alright guys thanks for all the tips, i got them installed! but now the car wont adapt and theres an awfully loud hissing whiny sound coming from the injector area but everything is bone dry and theres no vacuum leaks?
      The adaptation part can take some time and apparently works best if you clear the ECU by disconnecting the battery for a while (I left mine apart for 2 hours).
      Alice the Time Capsule
      • mpowerful
        • Jul 2013
        • 1273
        The chip centers around the injector size. In fact unless something is wrong (vacuum leak etc) you may only have a few mins of slightly lopeier than usual idle and thats it. Anyway im following to see whats going on and we have talked outside of this thread. Sounds like injectors may not be seated or there is vac leak somewhere. Anyway waiting on a video of the noise.
          • 34839
          Originally posted by peytonracer4
          i know you don't want to remove the manifold, but i PROMISE you it's so much easier. it will save you time and cursing.
          completely uneccesary to remove the manifold. that would make it 10x harder.
          • mpowerful
            • Jul 2013
            • 1273
            I will post a diy. I have been meaning to do this for a while. And yes 100% unnecessary to remove the intake.
            • mpowerful
              • Jul 2013
              • 1273
              Nando: I made a DIY over in the DIY section for injector installs. Needs mod approval though. Then I will link to here. Thanks!
              • Zreberlcoe
                • 1555
                and to be clear I have not installed the chip. Waiting on video to upload
                I have it pulled apart to the point of injectors and rail, now I have my clips on, they all seem in there pretty tight, what else should I check for a diagnoses?
                edit: I found gas in the head, is that a huge problem?
                BMW
                • Zreberlcoe
                  • 1555
                  Video on my flickr account
                  https://flic.kr/p/opzYsa
                  BMW
                  • mpowerful
                    • Jul 2013
                    • 1273
                    Where did you find gas in the head? I would install the chip. Thoseinjectors will run quite rich initially without a tune. Msg sent about the video. Sounds like a vac leak but not sure. Never heard that noise before. Doesnt sound like a grinding starter. Could be iacv noise perhaps.
                    • Zreberlcoe
                      • 1555
                      sitting under the rocker arms in little crevices of the head.
                      BMW
                      • FLG
                        • Sep 2011
                        • 3165
                        It's a vac leak. My guess still is that cover on the back of the intake where your missing a screw.
                        Also I'm unsure where you have found this gas?
                        Sent from my SCH-I545 using Tapatalk 2
                        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                        • mpowerful
                          • Jul 2013
                          • 1273
                          I wonder if the FPR is failing and sucking gas into the manifold....Although that still doesnt make sense as to why there is gas near the rockers. Thats just weird. Did you accidentally dump some rail gas into the head when pulling the old injectors. That rail can be quite full.
                          • Zreberlcoe
                            • 1555
                            Okay I'm going to the dealer to get a new vent hose because it seems cracked, that screw FLG is talking about and an intake boot to be certain.
                            BMW
                            • Zreberlcoe
                              • 1555
                              I don't believe so. If these hoses work and everything starts working, I'll pull the valve cover one more time to see if more gas built up.
                              BMW
                              • FLG
                                • Sep 2011
                                • 3165
                                Are you sure it's gas and not just oil? I don't want to state the obvious but just saying
