Another 2.7 Stroker Question
  • SDemetris
    • Jul 2014
    • 6
    Hey. I just bought my e30 last week so sorry for my ignorance. But I was looking into putting an i head on my eta. Ive read its a bad idea to keep my stock pistons and just slap the i head on it because the compression ratio will be too low. To solve that, couldn't I just shave down the head a bit? Or would there be interference between the valve and piston if I did that? Thanks in advance for your help.
  • digger
    • Nov 2005
    • 5957
    it wont really "solve" the issues of low CR or having non matched piston crown and combustion chamber so i doubt it will make a bigh difference but it might help slightly. cant comment on P to V with this combo not checked that myself.
    swapping a freshened head (not a junkyard one) is worth doing, if you do the swap
    • Gary Horneck
      • May 2011
      • 435
      Just slap a good i head, harness and sensors. Don't worry about the compression ratio. My 2.7i is a torque monster. Shocking difference, especially with cam and headers. My car ran .5 seconds behind a LS1 Miata all day, and 2 seconds in front of the rest of the class. It moves.
      2011 335i/1995 Mercedes C220 (rallyx)
      • SDemetris
        • Jul 2014
        • 6
        ok thanks guys. I think that when i eventually do this, i will probably keep my pistons as I dont have much experience inside the actual engine. everything else i can handle.. Any idea where i can get measurements on how much i can mill down the head? I can do that myself as i have access to a machine shop, but i need to know what will be safe
          • 34827
          have you dyno'd it? because none of the 2.7i's I've seen have been very impressive. "torque monster" seems to mean stock eta torque levels, almost as much power as a stock M20B25. yours could be different, just wondering.
          • Regnar75
            • Sep 2011
            • 483
            i have never dyno'd mine but even with the 2.93lsd it was noticeably quicker than my buddies 325i (both he and i thought so) but no dyno yet. there is some decent torque out of it, and top end is very nice, but its a huge improvement over an eta at least
            • timmyr77
              • Jun 2012
              • 353
              2.7i is definetly a big improvement of a b25. I lightened the flywheel on mine, no ac, chipped and head shaved .27mm. Torque improved a lot. Just to compare, I pull on my cousins m50 swapped coupe in my heavier vert.
              • timmyr77
                • Jun 2012
                • 353
                And you won't have valve piston contact if you don't mill off more then .25mm or so. If you want to go further, then you can buy a adjustable cam gear from bimmerheads to fix that issue.
                A lot if people advice agains a 2.7 build but if you do it right the first time it is definetly worth it. (Keep in mind I completely rebuilt the head and block) a fresh head and block will make a big difference as well.
                • Gary Horneck
                  • May 2011
                  • 435
                  I call it torque monster, so do the people that watch me autox it every month. Any 26 yr old, N/A car that can place in the top 6 RAW times out of a field of 85 cars is a torque monster in my book.
                    • 34827
                    ass dyno ftw :p
                    • digger
                      • Nov 2005
                      • 5957
                      reminds me of a saying i heard once, " when they cant make hp they start talking about torque....."
                      • Gary Horneck
                        • May 2011
                        • 435
                        Autocross/Rallycross results FTW ;D Only an ass rely's on Dyno data to strut one's stuff.
                        • SDemetris
                          • Jul 2014
                          • 6
                          .25mm? That's not even worth doing? And how is an adjustable cam gear gonna help?
                            • 34827
                            yeah, who needs a dyno test to verify the benefits of engine mods? ;)
                            • digger
                              • Nov 2005
                              • 5957
                              because engine is the most important aspect of setup for autoX? ;)
                              honestly for low speed racing a shorter diff does what you need but you get found out on a high speed circuit
