Another 2.7 Stroker Question
  • digger
    • Nov 2005
    • 6216
    Originally posted by Gary Horneck
    Autocross/Rallycross results FTW ;D Only an ass rely's on Dyno data to strut one's stuff.
    why not just post a chart i pressume you have dynoed it? it all adds value to the forum when people share. Sure some people who dont know any better will look at only one number on the chart and not be impressed if its not a high number but others like to see what works and what doesn't particularly with respect to area under the curve difference between 885 and 731 etc....not everyone wants a race engine.
    most impressive thing ive seen is a mild 2.7 pretty much match a S38B36 swapped E30 for torque below 3k at a dyno day....
    • timmyr77
      • Jun 2012
      • 353
      Originally posted by SDemetris
      .25mm? That's not even worth doing? And how is an adjustable cam gear gonna help?
      You will adjust the cam whatever number of degrees it needs to be adjusted so there won't be valve to piston contact if you do take enough off. You could also mill the block.
      I think .25 has a noticable enough difference. I haven't done te math but compression should be close to 8.75:1 instead of 8.43:1. That is higher then a stock 8.5:1 on the b25
      • timmyr77
        • Jun 2012
        • 353
        Speaking of hp and all that, I haven't dynoed my car yet, but what do you guys think my car would put down at the wheels? 150 at least?
        Specs :
        2.7 block rebuilt
        885 head rebuilt and shaved .27mm
        17lbs single mass flywheel
        Ac delete
        Power steering delete.
        Mechanical fan delete
        Dinan chip
        I plan on getting a m30 afm and 19lb/hr injectors and sssquid tune for that set up?
        What's your thoughts.
        Sorry op. Don't mean to high jack your thread
          • 34847
          B25 is 8.8:1 and isn't really enough for an agressive cam although a mild 272 will work fine
          • timmyr77
            • Jun 2012
            • 353
            I always read that the super eta pistons were 8.8:1 and thought the b25 was 8.5:1. I could be wrong
            • digger
              • Nov 2005
              • 6216
              that's ass about
                • 34847
                yeah, that's backwards.
                • timmyr77
                  • Jun 2012
                  • 353
                  Damn.... I've been wrong all this time.
                  • SDemetris
                    • Jul 2014
                    • 6
                    OK thanks. I'll probably just mill the head. I figure I won't take the block out unless it's actually necessary. Thanks for the help.
