Oil Pump Drive
  • Wardie
    • Oct 2012
    • 824
    Oil Pump Drive
    So, after doing my engine build through a builder. I noticed the oil intermediate drive shaft was not in the pump.
    So, is there anyway without taking off the oil pan to put it back in?
    Schwarz 1985 325e
  • digger
    • Nov 2005
    • 6170
    can probably pull the cap off the side of the block, there is 1 bolt holding/clamping a black bracket on. you can get access to the two needle sleev bearings, the gear and the skinny hex shaft
      • 37833
      So a professional engine builder did this? Scary. Wonder what else he forgot?!
      We recently came across a high dollar M10 engine that had the main cap installed backwards...
      Grover Beach, California
      BimmerHeads.com
      • Wardie
        • Oct 2012
        • 824
        Lets just say its someone who builds Pro3 cars.
        Also, I paid him to do it... but he made me do it.. He did give me some part I have no idea goes where. Maybe you would know? haha
        Schwarz 1985 325e
          • 34844
          it can't be the intermediate shaft (the timing belt won't go on without it) but the secondary gear & hex shaft that connects to the pump driveshaft. in any case, yes you can remove the cap on the side of the engine and put it on.
          • Wardie
            • Oct 2012
            • 824
            Do you have to remove the bearing thats in the block? I can't get it with the clips on the shaft.
            I also dont have the timing belt on.
            Schwarz 1985 325e
