Shaven 885 Head on ETA Bottom = 9:1 C/R Has anyone actually CC'd their own head?
  • 4x4_e30
    • Sep 2013
    • 164
    So, about putting an 885 head on an ETA bottom end. Apparently it's "common knowledge" that this combo leads to 8.3:1 - 8.5:1 C/R. I had mine shaved to 4.909" (minus .020" from stock). Upon further research, pretty much everyone has just regurgitated what they've read so many times nobody bothers to do any investigation themselves.
    I only found one other report of someone actually checking the volume:
    So I busted out the plexiglass, grease, and medicine syringe. Cylinder #6 came out to 37cc, #2 was at 37.75cc. Although my technique was not 100% exact, repeated measurements showed a tolerance of +/- 1/8th of a mL. The stock ETA head comes in at 38cc.
    I won't lie, using the 885 head with ETA bottom end greatly reduces the squish band area compared to the 200 head. But the compression ratio is actually a little higher than stock ETA.
    So, let the flaming begin!
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    Saw this post on FB, had no idea why you cared.
    With the eta bottom end, it makes sense now.
    Originally posted by priapism
    Originally posted by shameson
    • whodwho
      • Jun 2008
      • 1547
      Combustion chamber volume is not the only factor in the equation that makes for the CR, next measure the difference in the dome/dish of eta piston vs the b25i piston.
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • 4x4_e30
        • Sep 2013
        • 164
        The ETA bottom is still sweeping the same exact volume as it would with the 200 head. So if I push the same amount of air into a smaller place, why would I need to measure the "i" piston when it's not even a part of the system?
        • redlightpete
          • Mar 2012
          • 266
          Unless you have a completely flat piston that is flush with the top of the head gasket, you need to factor in the combustion chamber volume below the head.
          • LJ851
            • 7919
            Guys, it's not rocket science. If you remove the head from a given bottom end and replace it with another head having basically the same CC combustion chambers, the compression ratio basically doesn't change.
            Lorin
            The M30 is God's engine.
            • digger
              • Nov 2005
              • 6199
              this.
              if nothing else changes its just the delta of the head cc between the 200 and machined 885, which in this case is basically zero.
              taking 0.5mm off the head is ~3cc a basic calculation will show this.
              alternatively you could use a thinner gasket but that will cost more and its good to use an OEM gasket where possible
              • digger
                • Nov 2005
                • 6199
                It should be noted that a half a point of CR is probably good for about 3 or 4bhp. But if you ran a 272 cam or similar it would work a bit nicer with the higher CR. however the piston to valve clearance gets worse with both skimming the head and again with a 272 so be careful
