Camshaft Question
  • digger
    • Nov 2005
    • 6032
    Originally posted by Bullhead
    I have seen that in previous threads Dig but idk if the pedastils are there for the 3 added journals on the 325i cam. I will know more when I paint my valve cover next week.
    they are its the cam that is missing them IIRC
    • TobyB
      • 5218
      isnt it just adding some oiling holes on the 200 and you can run a 325i cam?
      Yep. Drill to connect the rocker tube to the cam journal.
      t
      • Cabriolet
        • 9620
        Hey, check this out.
        I just did a similar swap for a local guy. It's really not as hard as you are thinking it is.
        Caming the 200 head is a waste of money.
        the 200 head has single valve springs, smaller ports, and less cam bearings.
        adding the 885 head will be more of an upgrade than adding an cam to your 200 head.
        this entire swap can be done in 1 day is two people are working together.
        Much wow
        I hate 4 doors
        • HarteB
          • Sep 2014
          • 47
          + 1 .. junk the 200 head and replace it with the 885 b25 head ;)
          straight roads are for fast cars, corners are for fast drivers
          1982 e21 323i rs Hartge
          1989 e30 325i convertible
          1994 e36 m3
          • dirtie30
            • Jun 2013
            • 28
            I'm running a bone stock 300+k mile ETA bottom end with the top end from a 525i on it.
            I can't recommend this 885 head swap along with 1.1/1.3 Motronic upgrade enough. It's so fun. Faster than my buddies chipped 2.5l.
            Just grab a cheap $30 EEPROM from ebay to throw in the 173 DME and you're good to go. The stock ignition timing for the higher compresson 2.5l is too retarded for the lower compression ETA 2.7l bottom end. Most people forget about this and don't get the desired/expected performance from their 2.7i.
            • Bullhead
              • Sep 2014
              • 532
              I may just go ahead and scoop that swap up. I just need to con a TN guy on here into helping me for a day lol. I may be confused but I was thinking the 2.7 had a higher comp ratio than the 2.5.
              sigpic87 325E The Honey Badger
              • dirtie30
                • Jun 2013
                • 28
                not in the USA.
                I have both blocks in my garage and the 2.5 pistons are definitely higher compression than the 2.7 pistons.
                The internet is full of sketchy info on these things posted by people that have no idea what they are talking about.
                The valves in the 885 head are very close to the same size as the valves used in chevy LS heads. 885 >>>> 200
                • Bullhead
                  • Sep 2014
                  • 532
                  I know the 2.5 pistons had a better relief design but the 200 head itself has a smaller combustion chamber resulting in increased compression per the wiki. But again I am just a novice so don't mind me.
                  • dirtie30
                    • Jun 2013
                    • 28
                    There's only something like 4cc difference between the two. You're not going to notice a difference like that on the street with pump gas.
                    The internet will over analyze anything you want to do to death. Best advice I can give you is pick up a couple books on engine design and how they work, and a couple books on how various EFI systems work. Do your research, build what you want, and then show the internet. haha
