How to evenly apply oil pan gasket sealant
  • KMOSES
    • 591
    This is a easy way to apply gasket sealant evenly to a oil pan surface (for thoes that use sealant). This will mostly eliminate gobs of sealant oozing past the gasket. Needed, surface cleaner, riged back razor blade and 1/4" vinyl fine line tape (used for masking a car for paint). This tape makes smooth curves and is .004" thick. This may be a trick everyone knows but if you don't it it works well.
    Clean the surface well.
    [ATTACH]91259[/ATTACH]
    Apply the fine line tape to the inside and outside gasket surface staying about 1/16 - 1/8 away from the bolt holes.
    [ATTACH]91260[/ATTACH]
    Apply the gasket sealer of choice.
    [ATTACH]91262[/ATTACH]
    Use the razor blade to spread the gasket sealer.
    I apply enough pressure to the blade so that the tape color shows through.
    [ATTACH]91263[/ATTACH]
    Remove the tape to reveal a uniform coating of gasket sealant.
    [ATTACH]91264[/ATTACH]
  • packratbimmer
    • Dec 2009
    • 1335
    That is an AWESOME tip! I can't stand pulling an engine apart and finding silicone spaghetti everywhere.
    Thanks
    • TRAK WDW
      • Aug 2014
      • 157
      Great tip! Never thought of that tape idea... although it must be tedious, i'm sure it yields great results in the end!
      Harp
      • deutschman
        • May 2008
        • 5958
        While this is nice and I apreciate it, its WAY OCD.
        Thanks
        Gasket scraper
        • reelizmpro
          • 9557
          That's a neat trick but does it seal better than letting the two mating surfaces quench the bead?
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • AndrewBird
            The Mad Scientist
            • 11898
            Better yet is to apply a THIN layer to both surfaces, let both tack, then assemble. No need to use more than a thing smear, even less than you show actually.
            I'm not convinced there is enough sealant from hole to edge either. Those parts are already lacking in area and this method reduces it even further.
            • Dj Buttchug
              • Jun 2010
              • 7687
              this looks real nice but to get a good reliable seal you want that squish of the sealer between the metal.
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • KMOSES
                • 591
                I think the lack of area has less impact due to the higher clamping force around the holes. One thing I would add is that I like to wait overnight before torquing the oil pan bolts to spec. My thinking is bond the gasket well to each surface and let the gasket core handle the different rates of thermal expansion.
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  Totally agreed. It looks really nice, but there is just not enough sealant around the holes.
                  • Ether-D
                    • Sep 2011
                    • 2838
                    But this is just gasket sealant not gasket maker. Most gaskets generally hold fine without any sealant. This is just a way to add a little more protection incredibly neatly. OP, I like it. I don't have the patience to do it, but it is a very tidy way to do this.
                    Originally posted by Andy.B
                    I was born on 3/25…
                    • KMOSES
                      • 591
                      With a some manual dexterity the vinyl fine line tape can be curved around the bolt holes.
                      [ATTACH]91296[/ATTACH]
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        Originally posted by KMOSES
                        With a little manual dexterity the vinyl fine line tape can be curved around the bolt holes.
                        Nicely done!
