m20 crank sprocket, on m52 crank need to modify or should slip on?
  • kickinindian
    • 2327
    so like the title states should the m20 timing belt sprocket slide onto the m52b28 keyway after the crank spacer or does it need to be modified i kinda held it up to each other today and it looks like the sprocket side is too small
  • digger
    • Nov 2005
    • 6196
    should basically slip on to get it started then go all the way with some effort you can use the bolt to screw it in from memory, no need to modify the gear itslef.
    make sure the mating surfaces are immaculate, no dents etc that will score the surface
    usually use a puller to remove it so its not a sloppy fit that can usually be done by hand
    • kickinindian
      • 2327
      thanks digger! and i use the m20b25 crank bolt and conical washer/spacer too?
      so it would be oil seal spacer>sprocket>conical washer>crank bolt. correct?
      • redlightpete
        • Mar 2012
        • 265
        You'll need to cut the stepped section off the conical washer because the crank snout is a little too long. Also the m20 crank bolt is too long. The m52b28 one is shorter and works.
        • kickinindian
          • 2327
          damn it i bought the crank without the bolt could i cut my m20 one down and that would work?
          • digger
            • Nov 2005
            • 6196
            a unmolested bolt is about $20 or less from other places if you get stuck
            http://www.pelicanparts.com/catalog/...ENGMAN_pg1.htm
            i thought the m20 one was too short but could be wrong. m20 on LHS one i used for S52 crank on the right
            • redlightpete
              • Mar 2012
              • 265
              Maybe I'm remembering the bolt length backwards. Just make sure you have a reasonable amount of thread engagement and that you're not running out of thread depth before you fully clamp the parts together.
              • digger
                • Nov 2005
                • 6196
                updated pic to the correct one
                • kickinindian
                  • 2327
                  okay so i will have to get the m52 one then oh well good to know
                    • 37833
                    Yes you will need the 24v crank bolt and you will need to machine the washer down to sit correctly.
                    Grover Beach, California
                    BimmerHeads.com
                    • kickinindian
                      • 2327
                      putting this here for later
                      m52 crank bolt #11211720633
                      • 16vCorey
                        • Jan 2013
                        • 96
                        Yep, you have to use the M52 bolt. I didn't have to do anything to the washer when I built my M20B28, so I'm not sure what that's about.
                          • 37833
                          It will work without modifying the washer but it won't sit currently.
                          What crank spacer did you use?
                          BimmerHeads.com
                          • mikerob97
                            • Jul 2010
                            • 140
                            I am looking for information on where to buy the proper cranksshaft spacer and properly machined washer - does anyone know where I might find one?
                            Thanks in advance for any help.
                            Mike
                            Cary, NC
                            Current Rides
                            1991 325iC - For Sale
                            2006 M3 Cabriolet
                            Past Rides
                            2000 323i Touring - Daily Driver
                            1994 325is (S50) - Fast Car
                            1998 Z3 - Fun Car
                            1986 325e (i engine conversion)
                            1969 Mustang Mach 1
                            • abit
                              • Jul 2011
                              • 423
                              here is info about washer machining down: (as far as I remember, I even took more than 1,25mm off, by using the same crank spacer as he)
                              spacer dimensions:
                              http://instagram.com/mundieriss
                              my 88' m20b30 HERE!
