m20 crank sprocket, on m52 crank need to modify or should slip on?
  • SkiFree
    • Jun 2011
    • 2766
    Metric Mechanic sell them, as does Ireland Engineering (you'd need to email though, it's not on the general website). There was also a fellow selling them some time ago in the r3v classifieds (you'd need to google search).
    ADAMS Autosport
    • zaq123
      • Jul 2016
      • 1546
      Originally posted by redlightpete
      You'll need to cut the stepped section off the conical washer because the crank snout is a little too long. Also the m20 crank bolt is too long. The m52b28 one is shorter and works.
      I've seen a detail/ drawing for this work but can't find it now. Shouldve saved it. Anyone has it or can confirm the exact measurements for machining that washer?
      • digger
        • Nov 2005
        • 6163
        Had some junk parts laying around so assembled onto m52b28 crank
        BOLT:
        24V crank bolt is: 95mm Under Head Length (UHL)
        M20 crank bolt is: 65mm UHL
        so the bolt is 30mm longer
        you cant get even a single thread with the m20 bolt
        WASHER:
        when you push gear on there is a 2.85mm step (i.e. the snout is 2.85mm recessed below gear face) so the step on the washer would need to be approx 1.5mm to ensure that the bolt pushes on the gear rather than bottoming out on the snout.
        the stock washer has step 3.4mm long
        i have a washer supplied by Metric mechanic they reduced the step to 0.9mm so machined 2.5mm off it, but you could reduce it by less.
        Of course check when the time comes as there could be some small differences in the spacer length or gear overall length or snout length with alternate cranks to the m52b28.
        • zaq123
          • Jul 2016
          • 1546
          thank you sir. Does anyone know if M52 crank journals are treated? Will it respond ok to some cleaning/polishing or minor grinding if needed? Or it's recommended to find Crank that's close to new condition?
          • SkiFree
            • Jun 2011
            • 2766
            Treated? Yes.
            If you grind you need to nitride the crank. If you do a light polish, you should be ok.
            ADAMS Autosport
            • digger
              • Nov 2005
              • 6163
              i would look to get a crank that doesn't need more than a polish only, except in rare circumstances i might consider getting it ground to the next size and re-nitrided.
              • mikerob97
                • Jul 2010
                • 140
                I have a crank spacer and a set of 2.7 liter connecting rods available. I purchased for do do a 2.8 liter stoker build on my 325i, but never got to it. PM me if interested.
                Mike
                Cary, NC
                Current Rides
                1991 325iC - For Sale
                2006 M3 Cabriolet
                Past Rides
                2000 323i Touring - Daily Driver
                1994 325is (S50) - Fast Car
                1998 Z3 - Fun Car
                1986 325e (i engine conversion)
                1969 Mustang Mach 1
                • zaq123
                  • Jul 2016
                  • 1546
                  thanks for the offer but I have too many parts as it is: extra cranks, connecting rods, pistons
                  need to start selling parts myself soon.
                  I don't think cranks I got need grinding, they look very good for their age. Maybe very light cleaning/polishing if anything.
