Is it worth to build high rev M20B22?
  • Jasu
    • Oct 2007
    • 6
    Hi guys.
    I've always wanted to build a high revving short stroke M20 engine.
    And now it seems to be time to finally do it.
    Mainly in the planning stage, so I don't have all parts yet.
    Idea is something like the following
    -M20B25 block
    -B20 66mm stroke crank
    -145mm rods
    -85mm 12.5:1 - 13.0:1 pistons
    -885 head (40ml) with std. valves, new original rockers
    -~280ยบ @1mm ~12mm lift cam
    -42mm itb
    Fuel will be ethanol (RE85).
    Is there anyone here who has planned or made similar?
  • goarmy
    • Nov 2011
    • 622
    They will probably tell you to swap and go m50 or go s54
    • LateFan
      • May 2013
      • 4436
      Originally posted by Jasu
      Hi guys.
      -145mm rods
      School me on how this works, please anyone.
      You go with a shorter stroke crank, then put longer rods and/or taller pistons in to reach deck height for compression?
      So you have a short stroke, but more reciprocating rod mass? (unless you have really light rods?)
      It obviously works - most of the great race engines are short stroke, over square designs. I'm thinking of the Porsche 2.5 flat 6, or any F1 engine. I just want to understand the physics of the extra mass shaking up & down when you're trying to reach an existing deck height.
      -Engine design noob
      • nrubenstein
        • 3148
        It's interesting, but how many revs will that actually turn for a reasonable amount of time?
        If you want revs and low displacement, why not just get an S14? It'll be better in pretty much every way.
        2002 BMW M3 AlpinweiรŸ/Black
        1999 323i GTS2 AlpinweiรŸ
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 AlpinweiรŸ/Black
        • raudonis
          • Jan 2013
          • 184
          The problem with high revving m20 is not in the bottom end.
          It is in the head, poor lubrication between cams and rocker pads at high rpm because rocker geometry to be precisely.
          It appears that no sliding rocker design is up for the job. The only working solution so far is this roller rocker design http://www.racehead.com.au/?wpsc-pro...roller-cam-kit. The creator and seller of this is here http://www.r3vlimited.com/board/member.php?u=35745 He ran 2.7l in 8000 range, then stroked it 3.0l for better midrange torque and better general powerband.
          On the other hand, you can get m20 to 86mm bore with custom MLS gasket and for something small as 2.2l better use 731 head with bigger valves of 885 + flattop pistons.
          Also you will need properly sized ITBs instead of the factory manifold. Factory "crab" manifold is tuned for the midrange very strongly.
          You can try contacting this guy about high rpm m20 problems, he is Eesti ;) www.youtube.com/watch?v=xJO3C0j8F3U
          He used really expensive PPF billet rockers and most aggressive dbilas camshaft, but they just kept on grinding each other to death.
          His build thread is here, although most of the pictures are no longer working :(
          My transaction feedback on r3vlimited :):Clickety click
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            I got a m20b20 crank sitting in the block in my drive way.
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • digger
              • Nov 2005
              • 6213
              id start with a 731 or 200 head and heavily work it, as you wont need/want the same port volume that the 885 has in a small cubic inch engine and with a small cubic inch you want the small chamber volume to make it easier to achive a high CR.
              on e85 i wouldnt go below 13:1 especially with a huge cam like that
              also 40mm ITB will be plenty
              • TobyB
                • 5298
                OP is from Finland. They do NUTS shit there.
                I say go for it.
                But you WILL want a DOHC head to do it. That shouldn't be a problem, right?
                Frm M10 experience, the rockers really do limit you at a certain point, and that's
                probably going to be lower than the bottom end can take.
                Swap in an M88?
                Hee.
                t
                • raudonis
                  • Jan 2013
                  • 184
                  I say go for it.
                  Then swap over s50b32 head ant turn over 10 000 :D BTW swaping s50b32 head over m20 block has been done, there are a couple of vids on youfube from some German dude
                  Sent from my GT-S5570 using Tapatalk 2
                  • digger
                    • Nov 2005
                    • 6213
                    sounds like a bad idea
                    • Cabriolet
                      • 9620
                      OP for that cost, just get an s14. they can be wound higher and are in the same Liter-age as you are looking to get. they are lighter and pair with a much better transmission. i had a lot of fun winding the crap outa my m3.
                      Much wow
                      I hate 4 doors
                      • Jasu
                        • Oct 2007
                        • 6
                        I have in stock -731 and -885 ported heads (both with 42/36 valves and 40cc)
                        I know that with so short stroke it is difficult to get so high compression ratio, but the idea is interesting, and have had it more than 10 years in my mind.
                        I say go for it.
                        Swap in an M88?
                        Hee.
                        t
                        Doch head is not a problem, but money is. :D
                        Std rockers are ok ~9000rpm, if cam and springs are "correctly selected".
                        Basically, it would be wise. And my big dream.
                        But I have those M20 parts damn much. And one new Cosworth YB race spec engine. I should get rid of those first.
                        And now is not the seller's market.
                        • raudonis
                          • Jan 2013
                          • 184
                          • Jasu
                            • Oct 2007
                            • 6
                            Originally posted by raudonis
                            Believe it.
                            Course I would like to use roller kit, but the price is too high for me.
                            • digger
                              • Nov 2005
                              • 6213
                              standard rockers are not ok at 9000rpm for an extended period. gotta do it right if youre gonna do it. the billet rockers from VAC are cheaper than the roller rockers, then there is the heavy duty rockers (cast) that have been around for a few years now.
