Is it worth to build high rev M20B22?
  • raudonis
    • Jan 2013
    • 184
    There are also steel rockers from KM cams in Norway.
    My transaction feedback on r3vlimited :):Clickety click
    • nomansland92
      • 1657
      Originally posted by digger
      standard rockers are not ok at 9000rpm for an extended period. gotta do it right if youre gonna do it. the billet rockers from VAC are cheaper than the roller rockers, then there is the heavy duty rockers (cast) that have been around for a few years now.
      I always wondered what are the heavy duty cast rockers good till with stock springs?
      IX being restored here
      Ix turbo build here
      • Jasu
        • Oct 2007
        • 6
        I know that they may not last long, the same applies to any other.
        Usually a hard piece falls out, that's a problem of billet ones. HD rockers again are not very equal quality. And I've seen a lot of them broken, unlike BMW's original.
        Of course, that roller kit might be the best option. But the information about those just does not exist.
        edit. typo
        • Jasu
          • Oct 2007
          • 6
          Same that Enem ones.
          I have not heard any good of them. Are indeed cheaper than originals, so can not expect miracles.
          • digger
            • Nov 2005
            • 6189
            dont know what you mean by a hard piece falls out
            if you cant afford the RHD roller rocker setup then with conventional cam VAC billet will be the go. find a good cam grinder and make sure the pads are upto spec finish wise and squareness to the lobe as the PPM ones are junk in this regard and certainly need refinishing if you want them to last.
            • raudonis
              • Jan 2013
              • 184
              I think he meant
              • digger
                • Nov 2005
                • 6189
                are those VAC's parts? or PPM?
                edit those arent VAC those are the junk from PPM
                the feet on the PPM rockers are poorly done, they aren't square and hence you will get eccentric load which does all sorts of nasties
                • digger
                  • Nov 2005
                  • 6189
                  other sources
                  • mr2peak
                    • 2388
                    I'd love to see a honda K20 hybrid in an E30. High revving, proven, relatively cheap, and tons of potential. Basically a modern S14
                    Drive it hard. Maintain it well.
                    A Topless Memorandum
                    • TobyB
                      • 5287
                      The KM rockers for the M10 seem to hold up pretty well up towards 9000.
                      But the ONLY times I've ever broken even Febi rockers with voids has been when
                      the spring pressures went soft. I think that as long as the valve isn't allowed to float,
                      the rocker isn't the weak point. Up to the point where the valve spring breaks the
                      rocker on its own, or wipes the lobe from the cam, anyways.
                      But I'm just some guy with an internet connection...
                      heh
                      t
