m20 engine craziness
  • mikebloco
    • Feb 2015
    • 190
    Stupid thought.....so I know the i head is better in every way except the combustion chamber is bigger. So can you put the springs and cam from an i motor in a eta cylinder head and run it on an i motor. Compression ratio would raise slightly but the only thing that made me think of this is, is because eta heads are cheap as hell.
  • digger
    • Nov 2005
    • 6171
    pretty sure the domed m20b25 pistons will hit the eta head
    • Cabriolet
      • 9620
      yup. you cant put an eta head on an I bottom. it wont clear the crown of the piston.
      Also, OP, this could be the 3rd dumbest idea in practicality I've seen posted this year.
      Much wow
      I hate 4 doors
      • mikebloco
        • Feb 2015
        • 190
        yessss
          • 37833
          Eta heads are cheap for a reason. They are not desirable.
          You CAN modify an Eta head by porting/polishing to match i gaskets and drilling oil journals to make some good power but it would need to be paired with the Eta bottom end. It's a lot of work though.
          Grover Beach, California
          BimmerHeads.com
          • StereoInstaller1
            GAS
            • 22679
            I have a 731 I will sell you if you think you want a high compression 2.7l
            Closing SOON!
            Thanks for 10 years of fun!
            • 4x4_e30
              • Sep 2013
              • 164
              A standard "i" head machined down to 4.909" has a combustion chamber volume of 37cc's. The same as an "e" head.
              • mikebloco
                • Feb 2015
                • 190
                It's not that I want a high compression 2.7l, I just want my motor to not smoke as much. I'm going to do the valve seals this month and hopefully that's does the trick.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Aren't the ports on an eta head smaller than an i?
                  • Hooffenstein HD
                    • Nov 2012
                    • 1388
                    Yes. A lot smaller.
