Estimated Power M20 into 2002?
  • nerdydorkus
    • Feb 2012
    • 132
    Just putting the motor in the 2002 this weekend. Any estimated guesses what the power will end up being?
    M20B25 Stock motor
    Chip
    All emissions stuff deleted
    Power steering deleted
    No cats, 2.25" exhaust
    KN filter
    Crank scraper in oil pan
  • LJ851
    • 7918
    Same as in an E30
    Lorin
    The M30 is God's engine.
    • digger
      • Nov 2005
      • 6037
      150-155whp if its a freshish motor with good compression
      • packratbimmer
        • Dec 2009
        • 1331
        Does anyone know how a 2002 weighs in with an M20? Power to weight should be pretty good.
        • Todd Black 88
          • Oct 2007
          • 3449
          Originally posted by LJ851
          Same as in an E30
          I had this exact same response typed out about 5 minutes after the thread was posted, but thought, .........nah dick move, too easy.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • digger
            • Nov 2005
            • 6037
            the engine will make the same hp, but you might get different value at the wheels due to different gearing, friction, drivetrain inertia, wheel and tire combination...
            • packratbimmer
              • Dec 2009
              • 1331
              Yes, the 168MM ring and pinion should have a smaller drag value - I would randomly guess about 3-5%.
              • TobyB
                • 5218
                It will weigh 50 lbs more than it did before you put the M20 in,
                so anywhere from 1850 to 2450 depending on where you started.
                More importantly, it will have a bunch more torques. Tons more torques.
                And you will grin.
                And then your diff will grenade, and you'll add another 50 lbs in back going to a mid- case diff.
                hee
                t
                • Hooffenstein HD
                  • Nov 2012
                  • 1388
                  hee
                  t
                  The difference between small and medium diffs is a lot closer to 10kg/22lb.
                  • SkiFree
                    • Jun 2011
                    • 2766
                    Howabout adding those axles and custom subframe? Toby's accounting for more than just the diff.
                    ADAMS Autosport
                    • Hooffenstein HD
                      • Nov 2012
                      • 1388
                      I see. Just sounds like a lot of weight but I guess it adds up quick when using American units of measurement.
                      • TobyB
                        • 5218
                        The cases alone are about 40 lbs different- the 2002 case weighs 42-44 lbs, and
                        the E30 case weighs 83-88 lbs. It IS a heavy little sucker.
                        There are significant variations in both cases- the LSD small case weighs more,
                        the E21 early case weighs more, the late E21 case weighs more than THAT.
                        I think there are several variations in the E30 case, too, but I've only dropped the
                        4.11 LSD version on myself.
                        It's really surprising how different they are, I agree. I used to swap the 2002's
                        at the track pretty easily in about an hour.
                        I do NOT attempt the same thing with the E30!
                        t
                        • Wanganstyle
                          • 2828
                          t
                          very early E24/28/30 diff cases are heavier.
                          late model z3 188mm cases are lightest.
