2.7i Perfect idle, runs very rich with throttle
  • WildBill
    • Jan 2015
    • 54
    Just finished a 731 head swap on my 86 eta with 173 ecu. Has 19lb Mustang injectors, 325i TB and manifold, longtube headers, m30 afm, sssquid chip tuned for 19lb inj and afm.
    Test drove the car two days ago and it ran fine, had good throttle response and no stuttering.
    Yesterday, drove the car to a muffler shop and it started driving fine, then progressively ran richer and richer until it couldn't be given any throttle or it would backfire, and give no acceleration at all. At idle it runs perfectly fine, stable and air/fuel seems normal.
    Going to swap my afm with a known working one this afternoon, any other suggestions?
  • WildBill
    • Jan 2015
    • 54
    Also, brand new spark plugs were black when I pulled them. They don't even have 20 miles on them.
    • EatsHondas
      • Sep 2012
      • 404
      Is the chip for the M30 AFM?
      1989 325i Lachssilber Sedan
      5-Speed Swapped
      M30B35 Swapped
      MegaSquirt MS3X
      1987 325i Lachssilber Sedan
      260k OEM Automatic Daily Baby
      • WildBill
        • Jan 2015
        • 54
        Yes, the chip is tuned for m30 afm and 19lb injectors.
        • packratbimmer
          • Dec 2009
          • 1335
          I would ask if the chip is designed to match the flow rate of the 731 head. Correct me on this, but the 885 would flow a higher volume of air. Not sure if it would make enough of a difference to necessitate a specific chip???
          I had a challenge with tuning my M10 after putting my ported Metric Mechanic (MM) head on my stock 1.8 bottom end. MM does awesome work BTW - I was warned about the challenge!
          • WildBill
            • Jan 2015
            • 54
            I suppose that could make a difference but my 731 is port&polish. I don't see how that could change driving it the next day though, even unplugged the battery to reset any adaptation.
            • WildBill
              • Jan 2015
              • 54
              If I give the car any throttle at all above idle, it starts backfiring and then dies out
              • E30 Wagen
                • Jul 2005
                • 3434
                how do you know it's running rich?
                My Feedback
                • WildBill
                  • Jan 2015
                  • 54
                  Shooting flames and sputtering whenever throttle is moved. And you can smell the unburnt gas out the exhaust
                  • WildBill
                    • Jan 2015
                    • 54
                    Swapped in the stock eta afm and tps and it worked fine
                    • WildBill
                      • Jan 2015
                      • 54
                      Well, found out the problem was none of the above. The locating dowel on the camshaft snapped, causing the timing to be off until today, when it spun the pulley but not the camshaft. Valves hit pistons :(
                      Tearing the head off now. F&$@
                      • packratbimmer
                        • Dec 2009
                        • 1335
                        Ah man that's horrible - sorry!
                        • WildBill
                          • Jan 2015
                          • 54
                          It sucks man, 731 head is destroyed at cylinder 5, valve snapped off the stem and bounced around wreaking havoc. Piston disintegrated from it. There goes about a grand :/ now I'm trying to decide what to do next. Finding a 731 head is very hard in the US.
                          • WildBill
                            • Jan 2015
                            • 54
                            It sucks man, 731 head is destroyed at cylinder 5, valve snapped off the stem and bounced around wreaking havoc. Piston disintegrated from it. There goes about a grand :/ now I'm trying to decide what to do next. Finding a 731 head is very hard in the US. And I don't have the money for another right now.
                            • packratbimmer
                              • Dec 2009
                              • 1335
                              Pics? Is the combustion chamber destroyed?
