Bentley and timing belt
  • e30onBBSs
    • Dec 2014
    • 1347
    I've been seeing those "nightmare" threads and I am going to do the water pump/timing belt job. I have a bentley. Is there anything beyond the bentley worth noting? Any common mistakes to avoid?
    BMW tech
    Umass Amherst
    05 wrx sti
  • EatsHondas
    • Sep 2012
    • 404
    A very common mistake is to screw up the cam timing after replacing the belt. Once you have the new belt on, rotate the motor at least two full rotations and then check to make sure the cam and crank timing marks still line up. Then you can tension the belt. Even one tooth off can cause crappy running. Multiple teeth off risks valve-to-piston contact.
    Just be careful, don't rush, do one thing at a time. It's not a difficult job, just rather long.
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
    • e30onBBSs
      • Dec 2014
      • 1347
      Thanks Hondas!
      BMW tech
      Umass Amherst
      05 wrx sti
      • RobDog
        • Aug 2012
        • 188
        Mark your CPS and CID plugs because they are identical and can get swapped around causing a no start. The plugs are located under the diagnostic connector. Also take the hood off and the radiator out for more room.
        • redlightpete
          • Mar 2012
          • 262
          I've not taken the hood off for this job, but definitely pull the radiator. Get a wrench for the fan clutch nut beforehand, if you don't already have one.
          • e30onBBSs
            • Dec 2014
            • 1347
            Thanks for the tip, I will do the sensors for sure! And taking the hood off is a great idea as well especially because mine won't hold itself up so I use the jack pipe XD
            No doubt! Everywhere I've read says pull the radiator and luckily I already have the wrench. Thanks redlightpete!
            BMW tech
            Umass Amherst
            05 wrx sti
