Well I'm pretty sure my ICV is failing, anyone rebuild these?
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    i have an L-shaped ICV that is causing my idle to hunt a lot and set off the check engine light. which while not only costs 400$ but is also back ordered. i don't have that kind of money or that kind of time. SO does anyone rebuild these things or is there another cheaper option that i don't know about. Also I've tried cleaning it, its spotless inside but my idle still sucks and i still have a check engine light. thanks for the help guys
    88 325is Five Speed
    Lachssilber
  • ak-
    • 12422
    Stomp code?
    1991 325iS turbo
      • Feb 2012
      • 3580
      Originally posted by ak-
      Stomp code?
      I've tried a couple of times to do it and i can never get it to flash. i think i must have a 153 because my car is an early 88 build date.
      88 325is Five Speed
      Lachssilber
      • Gregs///M
        • Mar 2012
        • 2459
        Having a vacuum leak is much more common than a ICV failing. Try measuring the impedance of the leads in the connector. The Bentley manual has a good procedure.
        The ICV should buzz with car off, ign on. If you pull the ICV, the inner door should easily move around in a rotational motion open and close.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
          • Feb 2012
          • 3580
          The car didn't have this problem until I lifted the motor to change the mounts a couple of days ago, could vac leaks be bad enough to throw a check engine light though?
          88 325is Five Speed
          Lachssilber
            • Feb 2012
            • 3580
            also the icv is spotless inside and rotates smoothly when i shake it
            88 325is Five Speed
            Lachssilber
            • ak-
              • 12422
              This is a symptom of a bad TPS which could also relate to your idle and CEL.
              Check your ECU.
              1991 325iS turbo
                • Feb 2012
                • 3580
                Check your ECU.
                okay so i tried to do the stomp test and it won't give me the code, so i will be checking the ecu tomorrow morning. i did notice that the second i turned the key to the on position the ICV kinda clicked and started buzzing softly i take it this is a good thing?
                88 325is Five Speed
                Lachssilber
                • ak-
                  • 12422
                  Yeap, they buzz when you turn the key to ACC
                  1991 325iS turbo
                    • Feb 2012
                    • 3580
                    So it turns out i do have a 173 which makes me wonder why I've never been able to do the stomp test correctly. i took the intake and throttle assembly apart and found that my TPS is half way melted could that be it? Also the throttle body gasket fell apart the instant i pulled off the throttle body. the intake boot also looks fine and none of the vac lines look bad.
                    I don't think this should be melted by Matthew w wiseman, on Flickr
                    also im not sure what that hose is it was just hanging off the bottom of the throttle body and it has a massive hole in it
                    88 325is Five Speed
                    Lachssilber
                      • Feb 2012
                      • 3580
                      Also can I replace that boot with a vac hose, it was hanging off the bottom of the throttle body
                      88 325is Five Speed
                      Lachssilber
                      • RobDog
                        • Aug 2012
                        • 188
                        That hose goes to the carbon canister. It should have a inline purge valve between the throttle body and carbon canister. There is also a plug for the purge valve. I'm sure that was causing a big ass vacuum leak.
                          • Feb 2012
                          • 3580
                          theres also a huge hole in it
                          88 325is Five Speed
                          Lachssilber
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            That isn't melted, it's just covered in dirt and oil. Try scraping it off. Bet it comes right off.
                            If your TPS isn't working or isn't adjusted correctly, the stomp test won't work as the ECU needs to see a throttle closed and WOT signal. If it doesn't see one or the other (or both) it won't work.
                            • unitt01
                              • Oct 2014
                              • 513
                              You can replace that old beat up hose with part # 13311288284 Just cut it to the same size
                              FS: Plug n Play Second Trunk Light !
                              My Parts for Sale Thread~
                              x 1984 325e 2.7i ~ CastroMotorsport Built x Daily Driven
