Rear main seal newbie. "New" style or older spring style? - Kind of sealant?
  • Panici
    • Dec 2009
    • 2482
    I'm replacing the rear main seal on my E30, and I need some advice.
    I bought both the "New" springless seal from Corteco and the Elring seal with the spring.
    Which seal should I be using?
    To remove the old gasket material, I'm going to try to find some Permatex Gasket Remover, or similar.
    Now, for resealing everything, what should I be using? One of these or something else?
    There are two areas to seal.
    1. Between the carrier and seal (like this)
    2. Between the carrier and the oilpan/block.
    I've heard:
    • Curil T
      • Impossible to get around here
    • Permatex "The Right Stuff"
      • For Oil Pan (and also for RMS housing?)
    • Permatex Ultra Grey (EDIT: I think that should be Ultimate Grey)
    • Hondabond/Yamabond Grey
      • I'll have to special order it from a motorcycle shop.
    Any other suggestions/information you have about replacing the RMS would be welcome.
    I've never done this before, and historically gaskets and myself do not get along well.
  • reelizmpro
    • 9537
    Clean the mating surfaces good, the seal is installed evenly and not in an existing groove on the crank. I would use the Corteco without the spring. Make sure to install everything correctly onto the crank with the tool. I use hondabond/yamabond.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • SkiFree
      • Jun 2011
      • 2766
      I don't really like the spring-less seals all that much.
      That being said I answered your question about 6 months ago .... http://www.r3vlimited.com/board/show...15#post4311715
      (dirko and yamabond/hondabond are the same, Dirko is generally available to shops via Worlpac).
      ADAMS Autosport
      • Panici
        • Dec 2009
        • 2482
        So what I'm hearing is:
        • Use the PTFE/Teflon/Springless seal.
        • Use an anaerobic sealant
          • Designed for porous surfaces like the RMS carrier
          • I'm planning to get some Permatex Ultra Grey
        • Make sure the seal and the crankshaft are clean and dry (with brake cleaner
          • The initial friction at startup forms a mated sealing surface.
        • Use the included plastic sleeve when sliding the seal over the crank otherwise it is quite easy to fold the seal
        • Springless seal is harder to install, but done correctly it won't leak.
        Useful Reference:
        • efficient
          • Feb 2012
          • 3312
          Could be why my Trans is leaking because I used oil on the inside of the seal
          • Panici
            • Dec 2009
            • 2482
            So I've got it all installed.
            I used the springless seal.
            Is there any way to tell if the seal has folded over?
            Can I throw on a flywheel and start the car with no transmission attached to check for leaks?
