Rebuild
  • zaxxe30
    • Sep 2014
    • 103
    Rebuild
    I bent a rod on my m20 at 204k today. Should I source a good used engine, rebuild this one, or go with the m50/2 swap?
    '87 325ic
    '91 318is (first car) sold
    '99 m3 (sold)
    '84 porsche 944 (sold)
    '01 subaru legacy wagon
  • SkiFree
    • Jun 2011
    • 2766
    This question is asked on a regular basis, there is a lot of good information if you use the search function.
    At least provide some criteria to what you want out of the car.
    ADAMS Autosport
    • zaxxe30
      • Sep 2014
      • 103
      Looking for speed, smoother, easier to work on, reliability, and more modern. Money isn't that much of an issue most of the work will be done by me and my dad we own a mechanics shop
      '87 325ic
      '99 m3 (sold)
      • uturn
        • Dec 2010
        • 1005
        Smells like a m5x swap....
        I never did it because I got tired of sourcing parts and custom exhaust. Then there's the brake system to clear the intake manifold thing.
        • SkiFree
          • Jun 2011
          • 2766
          No. M5x is a waste of time compared to a decently rebuilt M20 (you will find that echoed frequently from guys who have been around a while). If you're swapping go with at least the s5x or an M30.
          ADAMS Autosport
          • digger
            • Nov 2005
            • 6171
            how much power are you after?
            if you want something more modern that kind of rules out the m20.
            m20 is ultra reliable if you do periodic maintenance (timing belt, good fluids, valve adjustments etc)
            if you want a decent step up in performance out of the box you want an S50/S52. with an m50/52 you need mods to make leaps and bounds over the m20 and it still wont have the torque of the S50.
            • Hooffenstein HD
              • Nov 2012
              • 1388
              Agreed, unless you go aluminium block. ~25kg of front end weight reduction is no trivial thing.
              • crappycoco
                • May 2014
                • 250
                M30B35 imo.
