What plug is this?
  • sneakyRedPanda
    • May 2015
    • 133
    What plug is this?
    This is the spot where the AC compressor should bolt on. The cord is fraying and will probably break soon. Is it an oil level sensor? Right side of picture is the plug in question.
  • Hooffenstein HD
    • Nov 2012
    • 1388
    Looks like the oil pressure switch.
    • sneakyRedPanda
      • May 2015
      • 133
      Cool looks like it. Anyone know where I can find a replacement cable?
      • digger
        • Nov 2005
        • 6194
        make your own
        • Ether-D
          • Sep 2011
          • 2838
          Originally posted by digger
          make your own
          This^
          It's just 1 wire. When it finally breaks, it'll just turn your oil pressure dummy light on (or it won't ever come on - not sure which, actually).
          Originally posted by Andy.B
          I was born on 3/25…
          • sneakyRedPanda
            • May 2015
            • 133
            Alright that's easy enough. I'll have to find something that won't melt. If I remove the plug temporarily to fab up the new wire, will the oil drain from that spot? Would I need to refill it substantially?
            • Klug
              • Sep 2011
              • 804
              You can remove the wire without removing the plug. It has a little metal clip that slides in that holds it to the switch.
              Just use a single 14GA wire and wrap it with electrical tape. It'll hold up with the heat- its the oil/coolant/grime that eats the wire up.
              555Garage - Kingston, PA
              '13 BMW e70 X5 35d
              '95 BMW e34 525i
              '92 BMW e30 325i S52 Vert (Quade the Vert)
              '92 Range Rover Classic
              '90 Range Rover Classic
              '89 BMW e30 325i Coupe (The DIRTY30)
              '81 VW MK1 Rabbit Caddy Diesel
              '76 Honda CB550K Cafe/Brat
              '67 Pontiac LeMans
              '24 Model T Depot Hack
              ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
              • sneakyRedPanda
                • May 2015
                • 133
                Alright sounds good, thanks for the help.
                • EatsHondas
                  • Sep 2012
                  • 404
                  The oil pressure switch grounds that wire with low or nonexistent oil pressure, turning your oil light on in the instrument cluster. Damaging this wire will prevent the light from ever coming on, not the other way around.
                  1989 325i Lachssilber Sedan
                  5-Speed Swapped
                  M30B35 Swapped
                  MegaSquirt MS3X
                  1987 325i Lachssilber Sedan
                  260k OEM Automatic Daily Baby
                  • 15Michaeljoseph
                    • Aug 2013
                    • 1693
                    And BTW since it wasn't answered: expect a drip or two of oil when you pull the switch... But not much more than that.
                    --Mike
                    (OO=[][]=OO) For Life
                    • sneakyRedPanda
                      • May 2015
                      • 133
                      Cool, thanks folks.
