Port on throttle body... Hose came out?
  • sneakyRedPanda
    • May 2015
    • 133
    I filled up on gas today and tried to start my car and it would just start then sputter off. There was a huge whooshing sound so I figured there was a massive vacuum leak. Popped the hood and found this hose popped out of the throttle body. There really doesn't seem to be anything holding it in. Is there a way to secure it?
  • AndrewBird
    The Mad Scientist
    • 11898
    Usually it's just a snug fit. I think the vacuum pressure helps hold it in. If yours is loose, a little gasket sealer would probably help.
    • sneakyRedPanda
      • May 2015
      • 133
      Yeah I've driven 1500 miles since I bought it and haven't had any issues until now. I'll try that. Thanks!
      • Mr. Tasty
        • Jul 2011
        • 3421
        most people use a little bit of jb weld.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • agent
          Vice Grand Pubaa
          • 7960
          Originally posted by codyep3
          cheap people use a little bit of jb weld.
          Originally posted by kronus
          • dnguyen1963
            • Nov 2011
            • 2651
            Hey,
            Don't pick on cheap people. Jb weld works really well for this problem.
            • AndrewBird
              The Mad Scientist
              • 11898
              I wouldn't use JB weld. A bit too permanent. Gasket sealer will be removable if needed.
              • uturn
                • Dec 2010
                • 1006
                I use that non-hardening window gasket sealer. That tar stuff you find holding the moisture barrier on newer car doors.
                • efficient
                  • Feb 2012
                  • 3312
                  So what's the proper way to fix this?
                  • TobyB
                    • 5287
                    Weld it in place!
                    t
                    (post pix when you do)
                    • efficient
                      • Feb 2012
                      • 3312
                      Lol I just used zip ties. Ghetto! I know, but I already used sealant but when it got hot it still came out
                      • ak-
                        • 12422
                        Mine is permanently put on there with some type of automotive cementing adhesive, I can't remember.
                        There's no reason ever to remove it from the throttle body anyways when servicing your car. The rubber hose it's connected to can come off instead.
                        1991 325iS turbo
                        • Hooffenstein HD
                          • Nov 2012
                          • 1388
                          Yeah, zip ties around the throttle body holds them all in place.
