Whining noise at idle?
  • E30_Narek
    • Sep 2014
    • 398
    Hey guys, I've been having this problem ever since I had the water pump, timing belt, and accessory belts changed but I just assumed it would go away after a while. I've been driving on these fresh parts for ~3k miles but the whining/whirring sound at idle is still there. If I rev my engine, it kind of sounds like a supercharger. The whining noise at idle comes on after the engine has warmed up. The car runs fine, doesn't hesitate and accelerates great. The whining noise is quite loud. The exhaust I have is pretty loud and I could hear the whining/whirring noise if I stand behind my car. The noises are coming from the front of the engine and I believe it has to do with one of the accessory belts or a pulley. What could be the problem?
  • TobyB
    • 5265
    I would be worried that the timing belt was misaligned/too tight/had a bad idler etc and
    I'd take it all apart again.
    But first, with the engine cold, take all the other belts off and see if it's quiet. That rules them out.
    t
    • E30_Narek
      • Sep 2014
      • 398
      t
      I was afraid it's the timing belt. That's one of the only things I wouldn't trust myself doing and I'm not looking forward to spending more money getting it done again :(.
      • berlow94
        • Jan 2013
        • 1063
        I would think its the voltage regulator in your alternator. Pop your accessory belt off and see if the noise goes away
        The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
        • E30-325iS
          • Sep 2011
          • 191
          It's probably the fan clutch. You can safely remove it and go for a short drive to confirm if it is causing the problem.
          • E30_Narek
            • Sep 2014
            • 398
            I have an electric fan.
            • ahlem
              • 369
              If you put the two parts of the timing belt cover on with the wrong one overlapping outward, it causes scraping that sounds like what you are describing. I did this once and thought I'd killed something.
              • crappycoco
                • May 2014
                • 250
                Does it sound like this?
                I have the same problem, and its driving me crazy
                • ahlem
                  • 369
                  I'd get a stethoscope and start probing.
                  • E30_Narek
                    • Sep 2014
                    • 398
                    Yeah mine sounds like that when revved but the idle noise is different.
                    • crappycoco
                      • May 2014
                      • 250
                      Any updates?
                      • E30_Narek
                        • Sep 2014
                        • 398
                        Any updates?
                        Not much, but the weird noise at idle seems to have dumbed down. Might just be my imagination, though.
                        • pandaiswong
                          • Apr 2014
                          • 112
                          I'm thinking the tension on the timing belt may be too tight depending on the method they used when they changed it. It really isn't very difficult to tear into your car and do it yourself if it comes down to it.
                          1992 Daihatsu Rocky SE
                          1988 BMW 325 SETA
                          • rturbo 930
                            • Dec 2005
                            • 2621
                            I just put my car back together, and I have a similar sound - like you said, like a little supercharger! I wish. It goes up with revs. I was thinking alternator, but I guess it could be the timing belt? I did it by the book, and just let the spring set the tension. Didn't seem like it was too tight, but I don't know. Makes no difference hot/cold for my issue though. I noticed it immediately on the first drive.
                            • pandaiswong
                              • Apr 2014
                              • 112
                              Did you turn the crank over when you were setting the tension?
                              1988 BMW 325 SETA
