Whining noise at idle?
  • rturbo 930
    • Dec 2005
    • 2619
    I don't remember. We did it by the book. My dad was helping me with it, will have to ask him later. But if it says to do that in the Bentley manual, then yeah, probably did.
    • crappycoco
      • May 2014
      • 250
      Perhaps its an timing belt issue with mine too.
      I tried the screwdriver method, and the noise was kind of coming from where the cover for the timing belt is. Could very well be what was mentioned about over tightening the belt.
      • E30_Narek
        • Sep 2014
        • 398
        Originally posted by pandaiswong
        I'm thinking the tension on the timing belt may be too tight depending on the method they used when they changed it. It really isn't very difficult to tear into your car and do it yourself if it comes down to it.
        If it is this, what would I have to do to make it less tight? I've never touched the belt myself so I don't know what to expect? Is it as easy as just opening up and making it a little loose or do I have to take off the timing belt and set it up all over again?
        • rturbo 930
          • Dec 2005
          • 2619
          Did you turn the crank over when you were setting the tension?
          I checked with my dad and yes we did do this. I didn't think it seemed too tight but you never know.
