2.7i Pros and Cons
  • jeffnhiscars
    • Jun 2011
    • 6010
    #46
    My machinist tells me I can get by with my b23 cam but should look at replacement options. Based on diggers cam profile post it looks Like a b25 cam is almost identical. Given that new ones are $130 is that a decent replacement ?
    Alice the Time Capsule
    • digger
      • Nov 2005
      • 6037
      #47
      i've heard mixed reviews of new febi cams, someone must have a good stock one around
      • jeffnhiscars
        • Jun 2011
        • 6010
        #48
        If I was going to install a used cam I'd stick with my "known used" b23. It's not at the end of its life but given the goal of not forcing a head pull til they bury me, I should explore my options.
        Is a re grind "as good as new" ?
        • 2mAn
          Señior Mod
          • 20468
          #49
          Originally posted by SkiFree
          howabout no. I always get a good chuckle at M52 kids (exception being Simon).
          a man after my heart :giggle:
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • jeffnhiscars
            • Jun 2011
            • 6010
            #50
            Btw I got these little puppies today
            They're in for a 30 degree back cut
            • digger
              • Nov 2005
              • 6037
              #51
              here is a flow test done by E21JPS of stock 885 with osvat valves i brought to his workshop when he was playing around with his new flow bench a few years back
              the osvat valves have a noticeable lip
              BLUE: Stock Osvat
              RED: Stock port, osvat backcut
              DK BLUE: a few of select grinding, osvat backcut valves
              so in total a few mins work but targetting the right areas...when you look at where the material was removed it was mainly shortside work very subtle. run your finger over the short side of stock port and a massaged one its much nicer by feel
              • jeffnhiscars
                • Jun 2011
                • 6010
                #52
                BLUE: Stock Osvat
                Talk about being right on point lol....thank you for the graph and yes, I noticed the lip right away.
                Rama was kind enough to provide me with some detailed guidance for ports, cuts etc which I have shared with my machinist. He will be doing a back cut and a 5 angle seat.
                I'm undecided about whether I let his son do the port work or do it myself now that it makes so much more sense to me plus I get the feeling he may be a bit grind happy.
                No cam decision yet.
                • digger
                  • Nov 2005
                  • 6037
                  #53
                  note that this was the 885 , the 731 has different bowl shape and short side apex so is going to require a little more work especially with an oversized valve. check out the guys work when you drop it off and decide from there
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    #54
                    The machinist I trust completely so am thinking to bring it home after the guides and valves are done and decide what's next from there
