Ticking and other problems after valve adjustment
  • Dzdimi14
    • Jan 2015
    • 158
    So I decided to do a little bit of a tune up on my car, New spark plugs air filter etc. I also did a valve adjustment. After I did the valve adjustment the engine just started ticking even louder than before. Thus, I did it again being super careful this time. This is when the engine developed the slightest bit of a knock and the ticking still remained. Feeling defeated I decided to step back and attempt next week.
    Here comes next week and I try to start up the car again but it didn't start. I turned the key and the starter made no noise but I heard a bang, as if one of the cylinders fired, then no sound again. Right after I heard the bang I turned off the car. The next time I tried to turn on the car, it started but I noticed a steady stream of white smoke coming out of where the headers meet the exhaust. I turned off the car to go to the bathroom and when I got back I started the car again and this time there was no smoke but it was still ticking.
    Any help as to what the hell is going on with my car would be much appreciated, I can post a video of the ticking as well if you guys need it.
  • george graves
    • 20003
    Eeek. Did you leave a wrench in there or something? Only way to see what's going on is to pull the valve cover again.
    Originally posted by Matt-B
    • Dzdimi14
      • Jan 2015
      • 158
      haha, already did that, nothing looked out of the ordinary
      • EatsHondas
        • Sep 2012
        • 404
        How are you doing your valve adjustment? Both cam lobes should be pointing down before you make a change. It's easiest to do it in the engine's natural firing order 1-5-3-6-2-4. Minimal engine rotating. Number 1 is closest to the front of the car.
        Did you double check the clearance after you fully tightened the eccentric? It's very easy to do this job improperly.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
        • Dzdimi14
          • Jan 2015
          • 158
          What exactly do you mean by both cam lobes pointing down? What I did was move the crank until each lobe was at TDC (pointing down) and then adjusted. I did this for each individual cam in the firing order that you specified above. I did check each valve after I adjusted it, probably too much, I went back and re-did most of them a couple times because I wasn't satisfied. And, I went through that whole process twice because I wasn't satisfied the first time.
          • digger
            • Nov 2005
            • 6199
            Do you use the spring loaded tool?
            • EatsHondas
              • Sep 2012
              • 404
              On each cylinder, you have an exhaust lobe and an intake lobe on the cam. When both of the lobes are pointing straight down, away from the valve cover, the piston is close enough to TDC that there is no rocker arm pressure on the valve. This allows you to set the clearance between the valve stem and the eccentric lobe on the rocker arm. I think we're talking about the same idea.
              When you're done adjusting, you want to be able to slide your feeler gauge through the gap with slight drag. If you can wiggle the rocker with the feeler gauge taking up the space, it's too loose. If the feeler gauge is stuck or doesn't fit, you're too tight.
              5-Speed Swapped
              M30B35 Swapped
              MegaSquirt MS3X
              • Dzdimi14
                • Jan 2015
                • 158
                Yea that's what I did, I got the lobe for the intake valve at tdc then adjusted it, then moved the crank until the exhaust lobe was at tdc and adjusted the exhaust valve. I did that for each cylinder in the firing order. I tried my best to get the slight drag concept down. I heard someone say that it is like when you drag your fingernail on a piece of paper so I based it off of that.
                • Dzdimi14
                  • Jan 2015
                  • 158
                  No, I just used a feeler guage, What does the spring loaded tool do?
                    The purpose of the spring tool is to make the adjustments easier by removing any subjective feel for how much drag is on the feeler or whether it is too loose. The task can certainly be done without the tool.
                    • digger
                      • Nov 2005
                      • 6199
                      its more of a pita without the tool, i always get more consistent result now i use it and it is much faster.
                      • TobyB
                        • 5296
                        You did measure the gap at the tip of the valve, right, not at the cam?
                        Saw that done once... confused everyone at first.
                        The other thing might be really worn eccentrics- if they don't get adjusted for 100k,
                        they get a big flat on them, and then when you do, there's just a sharp edge against
                        the valve stem, and it tends to be louder...
                        Had that happen a few times. New eccentrics helped a lot.
                        t
                        • FunkySwerve
                          • Feb 2015
                          • 43
                          Did you adjust it when it was hot or cold?
                          • Dzdimi14
                            • Jan 2015
                            • 158
                            cold
                            • Dzdimi14
                              • Jan 2015
                              • 158
                              t
                              yup, Ill look into the eccentrics to see if they are the problem. The camshaft itself looked pretty good though.
