camshaft gear bolt thread pitch?
  • madbim
    • Aug 2014
    • 33
    The bolt is 10x35 but does anyone know the the thread pitch? I have a 1.25 and it doesn't feel quite right.
  • jeffnhiscars
    • Jun 2011
    • 6011
    I just this to turn a camshaft. I used an exhaust stud if that helps :)
    Alice the Time Capsule
    • Fsnow
      • May 2015
      • 184
      Have you checked realoem? The more common pitch for that diameter is 1.5mm. I haven't removed a cam (m20 or m42 or s14?) So I don't know. You may want to be careful with the grade that you use for that application if you don't go with oem bolts. If it doesn't feel right, it likely isn't.
      1991 318is x 2 .
      • digger
        • Nov 2005
        • 6192
        m10x1.5
