ICV Ticking and Not Working
  • e30crazie
    • Feb 2013
    • 858
    My car has been idling pretty rough lately. The ICV is ticking as it should but hen I unplug it the car stops going up and down and smoothens out. Is it not working properly? Anyone has come across that issue?
    I am not sick, I am twisted. Sick makes it sound like there is a cure.
    1991 318is Diamantschwarz Metallic
    1989 325i Alpine White
  • Tim-sutherland
    • Dec 2014
    • 115
    I had something similar, cleaned it out with maf cleaner and some q tips and now it idles much better. It's easy so it's worth a try if you haven't already.
    • Gregs///M
      • Mar 2012
      • 2459
      Check the ICV using the method described in the Bentley manual. Also check your TPS to make sure its adjusted correctly or your ICV will never work right.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
        • 34844
        the ICV should hum, not tick. it runs at about 60hz.
